Regearing the front- what do I need
I am working on swapping my regular rear end on my Tacoma for the factory elocker version. Since my front end ratio will not match my back after that, I will need to regear the front end. What I want to know is, how much of a new front end do I need to buy to do this? Can I just buy a ring and pinion set or do I need to buy the whole front axle assembly?
I have a 2001 Tacoma 4x4 2.73RZ-FE 4cyl. The elocker axle assemblies can be found in 4.10 and 4.30 gearings, but the 4.10 rear ends were only put on the 6cyl Tacomas, but I believe that the rear end will fit on the 4.
I would prefer the 4.30 anyway, in which case couldn't I just get a ring and pinion set and have my mechanic change it out? Can I do that with a 4.10 ring and pinion, even though Toyota never made a 3RZ-FE with that gearing?
Should I buy a front axle assembly instead?
Thank you for your advice.
In any case you would have to remove the front differential. To install the ring and pinion, (have a pro do it) or purchase an already set up diff. Your Shop Service Manual should show how to remove the diff.
Former NH native, aye neighbor.
Flying91
45
Apr 11, 2024 04:39 PM
charlie_fong
Sep 27, 2015 10:06 PM
Mike Maiato
Aug 28, 2015 02:35 AM
