Code 21 and code 52 before and after head gaskets
Old Aug 10, 2013 | 08:17 AM
Cpasour's Avatar
I have a 92 Toyota truck with the 3vze. I was getting code 21 and 52 and discovered a HG leak. After new head gaskets still have code 21 and 52. I have already checked wire going to ECM and has a new pigtail I just don't want to put a $130 KS in if its not bad but truck runs like ˟˟˟˟ no power
Old Aug 10, 2013 | 01:05 PM
scope103's Avatar
Does code 21 have anything to do with head gaskets? (Hint: no.) You might want to fix that first; it's usually not too difficult, and you'd hate for it to be masking other problems.
How did you "check[ed] wire going to ECM"? The pigtail is the most likely to fail (and the Knock sensor itself not too likely), so the wiring end-to-end is where I would look next. Make sure you have continuity from the ECM to the sensor, and make sure the shield is adequately grounded (remember: it's grounded only at the ECM, not at the block or anywhere else.)
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
Coreyr384
Jul 10, 2015 11:13 AM
