guys running LC coils, drive line rubbing on gas tank skid?
I'm getting this issue when making a sharp turn or flexing the truck out. LC 8 and 7.5 wraps. I'm thinking of bending the skid where it's rubbing or cutting part of it away with a sawzall. What is causing this?
Honestly I don't trust the PH drop bracket to survive very long with the wheeling I do and as often as I wheel. Would it hurt to leave the PH bar in the stock location and just cut the part of the skid it is rubbing?
Will centering the axle fix the rub on the gas tank skid? Isn't this because of the angle of the pH bar? The drop bracket just doesn't seem very sturdy. I honestly might as well sell the LC coils and just order some OME rears for the cost of a adjustable PH bar.
Yes centering the axle should fix the problem. Its not so much the angle of the bar as the length. The adjustable one is spendy, but you have to remember when you change one thing it changes everything around it so you have to work thru all of it. Just part of modifying an automobile Lol. Good luck with what ever you decide.
zd92655
Mar 6, 2022 12:58 PM
crazypaint
Jun 23, 2015 03:27 AM
