Engine Swaps Swapping an engine in your Toy, here is where to learn how
3VZE/automatic to 3VZE/manual swap issues?
Old Jun 17, 2013 | 11:56 AM
JoshM's Avatar
Couldn't find much info on this so I'm looking for some answers here.
I have a 1991 4runner 3.0 manual with a dead engine
I found a 1995 4runner 3.0 engine but it has an automatic.
I want to take the 95 engine and drop it in the 91 but I am concerned about any differences that might prohibit that. Is the crank set up the same between the manuals and automatics or am I looking at issues with the pilot bearing set up? Are there differences with the wiring harnesses? I know the fly wheel would need to be swapped too. Is there any other problems or difficulties with making that swap?
From what I did find it sounds like the OBD-I system would be the same on both. Is that correct?
Thanks!
Old Aug 17, 2013 | 11:26 PM
bigarms23's Avatar
obd 1 is correct use the 95 wiring and motor and use the 91 ecu and the motor should bolt up fine to the manual trans
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
coryc85
Sep 9, 2015 06:24 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
Coreyr384
Jul 10, 2015 11:13 AM
