Opinions on a 1990 4runner
Old Apr 16, 2013 | 06:26 PM
FlamingToast's Avatar
Hey guys. I just registered after spending a ton of time lurking the last few days. Loads of great information.
I'm looking for some opinions on a 1990 4runner a friend of mine acquired in a craigslist trade.
Some info according to what the previous owner told my friend:
220,000 on the vehicle, 150,000 on the engine
v6, 5 speed, 4wd
32x11.5 tires that have seen better days
new clutch
light rust in front of the rear wheels, various dents and scratches
Interior is a bit on the rough side
Has a knock that gets much quieter when the plug wire for #4 cylinder is removed. From what I understand the most likely explanation for it is something bottom end, probably a rod bearing which basically means rebuild or run it until it lets loose and swap in a used engine.
Just wondering if you guys agree on it being a rod bearing and if you can think of anything else that would be good to check.
Also wondering if you think $500 is fair.
Attached Thumbnails Opinions on a 1990 4runner-4runner2.jpg   Opinions on a 1990 4runner-4runner3.jpg
Old Apr 16, 2013 | 06:28 PM
sorry. messed up the pic upload
Old Apr 16, 2013 | 06:30 PM
toyota4x4907's Avatar
I would buy it for $500. Good candidate for a 5vzfe swap.
Old Apr 16, 2013 | 08:06 PM
xcfunrunner's Avatar
^^ X2
I would buy it for 500. Do a 3.4 swap into it. I would just drive it until it goes bad.
Old Apr 16, 2013 | 10:28 PM
Also. Does anyone think its worth pulling the pan to check the condition of the crank? If measurements seem fine rod bearings should be all I need.
MMA_Alex
25
Apr 18, 2017 05:07 AM
tobylab
Jan 18, 2016 07:06 PM
tobylab
Jul 12, 2015 12:53 PM
madxman21
Jul 9, 2015 10:26 AM
ptb12
Jul 5, 2015 01:49 PM
