gasket or sealer? Thermostat housing neck
Old Apr 14, 2013 | 07:10 PM
DeadPhish's Avatar
Do you know if the thermostat housing area has a gasket or if the one that wraps around the actual thermostat is the only one needed. Its a 3vze 95 4runner 4wd. The kit came with the new oring type gasket that wraps the thermostat but I was wondering if the actual housing needed something.
Old Apr 14, 2013 | 07:17 PM
DeadPhish's Avatar
this is where i am talking about
Old Apr 14, 2013 | 08:42 PM
YotaWoRx's Avatar
Rubber fitted gasket is all u should need....
Old Apr 14, 2013 | 09:29 PM
hunter4runner's Avatar
Rubber gasket is best choice
Old Apr 14, 2013 | 11:24 PM
brianh699's Avatar
FSM doesn't call for anything but rubber gasket http://personal.utulsa.edu/~nathan-b...10thermost.pdf
Old Apr 15, 2013 | 08:39 AM
DeadPhish's Avatar
I will have to pull it and make sure I have the Jiggle Valve on the top, thanks for that link.
The ring/seal that came with the rebuild kit didn't fit like the original. It was larger in diameter so I reused the old one. It looked to be in pretty good condition and if it leaks it is pretty easy to get to and replace.
the1998sr5
15
Jul 14, 2020 08:35 PM
Flossy
Aug 5, 2015 05:14 PM
horunner1x
Jul 10, 2015 06:33 AM
Edionne13
Jul 9, 2015 01:59 PM
