Tire Clearance for Flatbed?
Old Mar 31, 2013 | 01:38 PM
Marshmonkey's Avatar
I have a 2005 4 door Tacoma 4x4 TRD Package. I'm going to put a flatbed on it and wanted to know how much clearance was needed between the top of the tire and bottom of the flatbed?
Old Mar 31, 2013 | 03:08 PM
dropzone's Avatar
Fossilized
Same as you have now
Old Mar 31, 2013 | 03:52 PM
SCToy's Avatar
get as much weight as you can reasonably in the bed, measure the distance from the axle to the bump stop. whatever that measurement is, you'll need that much space plus like another inch or 2 above the tire. That way if you ever fully bump the truck out, you won't hit your tires into your bed, you'll still let the bump stops do their thing. Remember rubber bump stops do crush a fair amount.
Old Mar 31, 2013 | 03:53 PM
SCToy's Avatar
Plus if you ever go up in tire size you'll be glad you left that room.
Old Mar 31, 2013 | 04:17 PM
ThatGuy1295's Avatar
And articulate it fully in a dich or ramp. And take measurments off the frame, then compare to your flat bed build. SCToy has good advice, but the tire can still go higher when articulating then it can under level suspension compression.
Its time for a cave man drawing to explain
Old Mar 31, 2013 | 05:10 PM
SCToy's Avatar
Good thinkin thatguy!
foampile
Dec 18, 2022 01:29 PM
djpg2000
Nov 11, 2020 04:56 AM
89fourrunner
Feb 17, 2016 06:52 AM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
coffey50
Jul 28, 2015 10:55 AM
