outer tie rod end
Old Mar 18, 2013 | 08:50 AM
carly777's Avatar
outer tie rod end
97 4rnr 4x4 sr5 auto, i need to replace the pass. outer tie rod end, do i need to do the drivers side as well, or can i just do the pass. only
Old Mar 18, 2013 | 10:38 AM
wyoming9's Avatar
Red face
It all depends if you have the extra to rebuild the whole front suspension go for it.
If not just fix what is needed .
If you measure things and get the new one on just like the old one you might not need a front end alignment.
Are you having this done or doing it yourself??
Might help you to decide.
Old Mar 18, 2013 | 11:51 AM
carly777's Avatar
[quote=wyoming9;52055430]It all depends if you have the extra to rebuild the whole front suspension go for it.
Might help you to decide.have a friend that can do it
Old Mar 18, 2013 | 04:23 PM
wjwerdna's Avatar
you don't _need_ to do both, but obviously you should check... I couldn't get my inner and outer separated when doing inner last time, so replaced both (I am sure real mechanics have a trick to break them free?)
krimsonone
Sep 13, 2024 09:33 AM
Sep 4, 2015 09:27 AM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
ahriman
Aug 1, 2015 10:38 AM
ripp96
Jul 25, 2015 02:32 PM
