needing some help with brakes
so i have a 1984 yota that i have mono linked in the rear with fox air shocks. so there are two braks lines going back to a lspv. i dont wont to run the lspv. i would like tp have a single line going down my link stright to the rear end. so what im askin is how do you bypass lspv.
I removed my lspv and blew the seals in my master first time I hit the brakes. You need a proportional valve. What I ended up doing was building a bracket with a screw adjustment for the top of the stock valve and mounted it under the hood. Then just run your one line back.
