98 4Runner will not start - have confirmed all parts are good
My 98 4Runner died while driving and the oil lamp came on. It started again after 30 minutes and ran fine for a few days. The it did it again. I had all parts and engine codes checked with a mechanic and there were no issues. He is saying to take it to Toyota because its due to the factory security system.
All lights etc. work fine but the engine will not even try to crank. Any help would be appreciated.
Fuses, relays, ground wires, all electrical connections.......inspect everything carefully.
So, if I understand it you have two issues:
1) starter will click and not turn over periodically
2) rig dies while running with no check engine light or codes stored?
Has the oil lamp came back on after the initial occurance?
Did the mechanic test any electrical components i.e. crank sensor, cam sensor, etc?
voiddweller
19
May 2, 2016 09:10 PM
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
XtremeOff-Road
16
Jun 27, 2002 07:32 PM
