4 runner lift install
Old Feb 22, 2013 | 09:31 AM
yota81's Avatar
Looking to put a toytec full 3in kit (OME) on a 2000 4 runner. I'm getting the diff drop spacer as well, but is there anything else that I will need? Any special tools or other things that you became aware of while doing the install...such as extended brake lines, etc.
Thanks
Old Feb 22, 2013 | 12:33 PM
akaphilly's Avatar
definatly get the poly steering rack bushings. the stock brake lines will work just fine.
Old Feb 23, 2013 | 09:45 AM
RMSlayer's Avatar
Yes, to the poly steering rack bushing kit. i also did an adjustable pan hard from Sonoran steel, as my driveshaft was getting pulled to the passenger side. Im also considering the rear brake load sensor bracket, also from Sonoran steel. If youre going to do 285's, spacers may be needed if you have OEM wheels.
voiddweller
19
May 2, 2016 09:10 PM
vasinvictor
Jan 20, 2016 12:39 PM
live4soccer7
Sep 3, 2015 12:29 PM
88Toy
7
Jun 17, 2015 09:40 AM
dandownunder
Jun 10, 2002 06:18 AM
