99 Tacoma 2.7 starts missing as fuel level declines
Old Jan 25, 2013 | 06:29 PM
mooserov's Avatar
My tacoma has a misfire/fuel starvation issue when the needle starts to get off of full. it died completely on me when it got to around half.
Previous owner said he had the fuel pump changed (bosch), but didn't give a reason why. Got the truck for $3800 with 180k on the odometer. 2wd.
I don't want to dump a ton of money into it, but here's what I've done so far.
New plugs,wires,pcv,air filter(tune up stuff) changed all fluids, cleaned maf, cleaned IACV, cleaned throttle plate, seafoam, New fuel pressure regulator (idle would speed up when I pinched the return line from the FPV).
Any suggestions?
Old Jan 25, 2013 | 06:41 PM
Xeo's Avatar
Xeo
Has the fuel filter even been changed?
Old Jan 25, 2013 | 07:27 PM
mooserov's Avatar
yep, forgot that. did it with the tune up
Old Jan 25, 2013 | 07:30 PM
mooserov's Avatar
I'm beginning to suspect that something isn't kosher in the fuel tank. I don't know exactly how everything is put together, but it makes sense that it may be a pickup tube issue, or something not seated, bad o-ring type issue.
The problem completely goes away when I fill up.
Old Jan 25, 2013 | 07:35 PM
Xeo's Avatar
Xeo
No CEL?
Old Jan 25, 2013 | 07:47 PM
mooserov's Avatar
No CEL
Old Jan 26, 2013 | 05:06 AM
youngtoyotatech's Avatar
unless there is just something else not noticed yet, i agree. Probably a crack/hole in the pickup tube and once the fuel gets below the hole it leaks amd you loose pressure. If a fuel pump was just done maybe someome was rough on it when pulling it out/putting it in.
Old Jan 26, 2013 | 05:22 PM
mooserov's Avatar
how hard is it to drop the tank on these trucks?
JF9243176
Oct 8, 2017 04:21 AM
Jake 85 sr5
Jul 1, 2015 06:49 PM
94 bikehauler
Jun 30, 2015 11:19 PM
rbravo1
Jun 29, 2015 01:34 PM
JF9243176
Jun 24, 2015 04:53 AM
