Stuck in 4x4, help
Stuck in 4x4, help
hi guys, i have a 90'4runner,
its stuck in 4x4, i think i might need a new transfer case
but i was wondering if there is any way that i can disable 4x4
an just run it on 2wd the whole time,
thanks in advance!
thanks in advance!
well, i tried it and its still stuck in 4x4.
when i put it in 2wd it jerks and it almost sounds like some broken gear teeth rubbing together, which is unbearable so i have to switch it back to 4x4 for it to runs smooth.
You can alwasy drop the front driveshaft. Not the best solution (that would be to fix it, of course), but one that would definitely get you out of 4WD. It would still be engaged in the T-Case, but may let you get a little further down the road for the time being.
when my 4x4's that i've owned bind up and do not want to shift back to 2wd, i just get it rolling in first gear, let off the gas and shift it (transfer case) at the same time.
this noise could be something more serious. but first get it out of 4wd and unbound and see what you got.
pyramid
Jul 29, 2015 06:53 AM
FS[SouthEast]: 87 toyota pickup 4x4 22r
Yota.Jay
Jul 26, 2015 05:50 PM
Could be torque bind from being unable to slip enough!!
