88 toyota 4runner starting issues...
Old Jan 7, 2013 | 03:08 PM
Chaviator's Avatar
This is another issue besides the other ones I have already posted. I have a clutch switch on the dash that I used to push before starting the truck. It was working fine and at some point stopped working and I had to start pressing the clutch in order to start the truck. Now some times neither of them work, the clutch push switch nor the clutch pedal. When this happens, I have to get out of my truck, having the key switch open, connecting a wire from the starter ignition connector straight to the positive of the battery to start the truck manually from the engine area. Ones it turns on, I go ahead and disconnect the wire I used to start it, reconnect the ignition connector and close the hood. This had happened several times and some of those times it has been very inconvenient to me perhaps because I am dressed up or it is raining in which I can get dirty or wet. Any ideas of what is going on here. Honestly, the only thing I've done is to clean he connection on the starter, check the connections on the clutch start switch, inspect the wires on the key switch area and nothing unusual. Once again, some times this switch works but not most of the time and the clutch also surprises me not working either. Thanx guys!
Old Jan 7, 2013 | 03:58 PM
B-Fake's Avatar
There should be a small plastic connector on the bottom side of the starter, I think it goes to the relay maybe. Give it a good jiggle or unplug it and clean it. My truck did the same thing for a while and jiggling that plug around fixed it.
Old Jan 8, 2013 | 04:16 AM
Chaviator's Avatar
I think that is the connector i am taking about that i disconnect in order to connect the wire that i use to start the truck manually. Then i connect backup once i start the truck. I will check again to see if there is another plastic connector. Thank you...
Old Jan 8, 2013 | 07:04 AM
96vettelt4's Avatar
its the connector..got to be hooked up..
Old Jan 8, 2013 | 12:22 PM
RAD4Runner's Avatar
Looks like your starter solenoid (pigybacked on starter motor) is good, but there is no power getting from starter relay to the solenoid.
Next time this happens, I suggest you do this quick check:
While pressing on Clutch OR with clutch safety cancel switch ON, attempt to start.
Do you hear a click behind the glove box? That's the Circuit Opening Relay. If it clicks, your ignition switch is good.
Does starter relay click? If you do not have an assistant, use RAD4Runner's Special Service Tool here =D
If starter relay does not click:
1) Disconnect relay from connector
2) Put negative side of voltmeter on thin black wire with red stripe, pos side of voltmeter on black wire next to it (NOT on black wire diagonally across thin wire)
3) Attempt to start as usual
4) You should get 12 Volts.
If you get 12V volts there, relay coil is likely bad. Check continuity.
If you do not get 12Volts trace positive side of circuit back to ignition switch, negative side of circuit to clutch safety switch (near pedal)/clutch safety cancel switch (dash).
Starter relay clicks but solenoid does not do a thing:
1) Disconnect brown connector thick (AWG12?) from solenoid
2) Attempt to start (starter relay should click).
3) Measure voltage at connector pin. You should get 12V. If you do, chances are your wiring is flawed like many 86-88 4Runners. You get 12Volts there but once solenoid loads the circuit, there is too much resistance in wiring that there's not enough current to energize solenoid coil. Many still work with the flaw because after all there are Toyota's, and Toyota robustness could mask a problem. Wiring flaw is explained here.
Clean and Robust Fix for that wiring flaw is here
86-88 4Runner cranking system explained
Old Jan 9, 2013 | 03:20 PM
Chaviator's Avatar
Thank uou so much. I have not gotten a chance to get back and try any of the mentioned suggestions, but as soon as I have a chance, I will do the tests, hopefully I figure something out there, I really hope so. I am tired of dealing with this...!
arlindsay1992
Jan 23, 2024 01:34 PM
vasinvictor
Jan 20, 2016 12:39 PM
JaredL
Jun 16, 2015 04:47 PM
