building dual cases
building dual cases
i'm building dual cases for my 87 4runner the case thats in it now is a 4.7 top shift and the donor case is a 2.28 top shift. i'm wondering what needs to be done to the 4.7 thats in it now to be the rear case
nothing at all unless you want to make the rear a twin stick.
However you will have to make sure that you order the adapter plate that works with your rear case.
Unless you have a turbo or v6 application you have a 21 spline output on the transmission. and that would make your current gears 21spline. In other words unless you have 23 spline which we could determine with more information. you need to make sure you order an adapter plate with 21 coupler.
The way I made my dual cases was by ordering the 4.7's and the doubler at the same time so I could go
Transmission 21>reduction box 21>adapter plate output 23>4.7 rear most transfer 23.
Just to add a little more strength but like I said ASSUMING you have a 21 spline transmission and already have 4.7 gear in your truck you will have to go 21 spline all the way down the drive line.
EDIT: in some cases you need to chop of 1/4 inch of the shift rail on the rear most case so things dont bind up.
Marlin can help you find out which one you have:
http://www.marlincrawler.com/tech/tr...fer-case-bible
priest16
15
Aug 6, 2015 07:43 AM
crashburnoveride
Jul 10, 2015 06:39 AM
toyoda8488
Jul 5, 2015 10:18 PM
