1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....
Old Dec 19, 2012 | 04:03 AM
ChefYota4x4's Avatar
I'm in Palos Verdes Peninsula, CA., 90274.... Local pick up is fine... Shipping after payment is received is fine as well.
I'm just trying to help out Mom's after her Hubby's passing...
I gathered this stuff over time, from PYPart and private sellers... And NONE of it was free... And some of it was a PITB to remove, etc. I've tried to do MANY "favors" and solids in the spirit of 'paying it forward'.... but in this case, I need the money to help keep Mom in her own home.
Much of this stuff is pending(and will be marked as such)... BUT, as we all know, many times people, for whatever reason, can't get the cabbage together(which I FULLY understand)..... Soooooooo, ...just saying, if you're interested... SEND ME A PM, and I WILL get back to you PROMPTLY, ok? If it sells... I'll mark it as such, within hours. If it becomes available from pending.... I'll mark it as such within hours.
First come first serve....
I know it's not the end all be all list... BUT, ... people HAVE asked me for this stuff... So we'll see.....
NO PRICES include Shipping unless otherwise noted...
NEWLY ADDED ALWAYS AT THE TOP;
1st gen 4runner/2nd gen pu skid plate...Not a dent on it/No rust....$30
1980 axle, complete end to end, with original third member with 4.37 gears.... $100... ( I will sell the third member alone but I really didn't want to part it out as I want to get this whole axle out of here. If not, I may hold on to the third member and get rid of the axle.....We'll see)
87 4Runner leaf packs and u bolts and mounting plates w/shock mounts with all hardware/minus bump stops.... $100
85 SFA with TG truss and Knuckle gussets (HOLLOW, no knuckles or otherwise)....$60...
87 4Runner/NON-ADD/ IFS front 7.5" third/ 4.30 gears _/tube and cover sealed and in tact (someone COULD run the 4.37 geared third I have in the rear, behind this third, and have a much better time on hills and on the trails...I know as I ran the 4.30's in place of my 4.10's and that lil difference was huge on the highway even on 32's)....4.30 full front axle assembly w/tube: $150 (have mounting stuf-bolts and nuts included/You can shave off the splines and make quick cv change set up)
1k miles-Slotted & drilled 94 V6 beefy rotors....$50 ../ Fully refurbished Aisin Manual locking IFS Hubs.... $140 (new OEM o-rings, star gasket & spring and ball... need a lil paint or can powdercoat dial and ring for another $40)...../87 4runner wheel hubs with nearly new KOYO Japan bearings and races.... $80 for both hubs.../backing plates.... /Spindles in great condition... $40 .... (all these parts are either nearly new or at least very well maintain consistently! ..... $270 for both sides sold complete, with knuckles and backing plates, etc! (Add $40 for newly powdercoated dials and rings)
4.10 4cyl 8" third member/4.10 4cyl 7.5" third member w/out tube or inner axles..... VERY good condition factory thirds, ..... $80 each.....(can dig out the 4.10 third if someone needs pics)...Front....
87 4Runner Front bumper w/signals, mounting brackets, plate/bar and end caps (bumper has 2 small dings and drilled small holes on top for light bar/grill guard mount it had... could mount an LED Light bar or slim lights in holes)....$120
WARN Premium all metal manual locking hubs...NEVER ONCE gave me a problem(only problems I know of are when used with Straight axles).... NOT ONE BOLT was loose when I removed em. Very minimally used and look/are like brand new.... All hardware EXCEPT 54mm bolts and star washer kit. I have some I will provide/stock Yota stuff.....$100 (these are more than 2x this much new and I DO recommend them as they never gave me a problem! Dials turn like a hot knife through like butter!).....
1st gen 4runner roll bar pad ....mint.....$40.....
87 4runner IFS front axle sub-cross member w/bolts & nuts... $20....
Complete Ifs front end and torsion bars-w/hardware from 89 V6 4Runner/ automatic locking hubs still attached to rotor-hub-spindle-backing plate and knuckle assembly... 2 sway bars, all 4 uncut Control arms, steering rods and rod ends, idler arm seems to be fine, pitman arm, .... rancho stabilizer and mounting bracket.... $140 for all, local pick up only....
1983 4wd PU front driveshaft... $20(might be spoken for....PM me
2 Pairs of Mint Condition Gray 1st Gen 4Runner B-Pillars...... 30$ a Pair
1st Gen 4Runner Tailgate "TOYOTA" labeled Key Cylinder and License Plate Light Housing/Corrosion Free......40$
88 4Runner Glove Box......20$...
88 4Runner 22RE TPS with Connector and retaining clip...... 25$.....
88 4Runner 22RE ECU...... 100$....
1st Gen 4Runner SR5 Maplight with Mounting Bracket and all Hardward and wiring w/connector.....40$(I have SEVERAL, all listed below as well...all clean, all complete... But now have a Gray one again, thought I'd post it....
22RE Dashpot with filter basket/slower-one-way valve on vacuum hose- from 88 4Runner (I'm betting it likely works in most 85+ 22RE Rigs) in GREAT condition, resists smoothly on downtravel and does NOT STICK whatsoever.. Ready to mount..... 35$
2 more 1st Gen 4Runner rear window relay modules....... 50$ Each.......
Full set of 4 - 1988 4Runner 22RE Injectors("Reds") with connectors in great condition and some wiring to connectors(I would not have cut them, I HATE THAT in the yards.. but someone had already hacksawed the whole harness FOR SOME REASON! hahaha.... ) ..... Just need to send them off to Witchhunter! .....60$ for all 4!....
1st Gen 4Runner Gas Door in Perfect Condition, ready to bolt in...LOCKING STYLE!!!! SO YOU NEED TO SWAP YOUR LOCK CYL or take Key Code from Cyl in there and order a set of keys......
Cold Start Injector Time Switch from 88 4Runner...... 15$....
ALL hinge and striker hardware for 1st Gen 4Runner.....50$ ...... Seat Bottom Release Straps/Hinges..... 30$ ... 75$ for all of it/ ALL in great condition! .....
2 Pairs Aisin IFS Manual Locking Hubs.... 80$ each....
3rd Gen Celica/4Runner Replacement...>> Shifter Knob, drops right on our 1st Gen 4Runners, etc., 20$
Found another Gray 2nd Gen 4Runner Maplight(2 Festoon style, many, like Bryan89 have installed them up front for DAYLIGHT effect with LED's, etc., in place of the lightless stock first Gen 4Runner Mirror Apparatus); 30$...
85 Supra engine Bay light(activates when hood is opened and light pops off and extends quite a bit to hang on the hoods-underside or light up a tire change / GREAT condition lens) ; 25$....
2nd Gen 4Runner Power Mirror Switches(2 types, 2 of one type and 1 of the other type connector... One is reserved already, waiting to see which connector he has) ; 15$ each...(ONE- 7/ROUND PIN, SOLD)
2nd Gen 4Runner(Maybe other years it would work, especially if spliced in) REAR Heater Switch/back of Console; 15$ ......
2nd Gen 4Runner Door Control Relay Modules// 2 PART #'s... All of them I have are shown in the picture(minus one ending in "107"-SOLD); 40$ each.......
2nd Gen 4Runner REAR Window Relay Modules; 50$........
2nd Gen 4Runner Electric Mirrors; 75$(THIS PAIR-SOLD, BUT CAN GET MORE IN MINT CONDITION/OEM/IF ANYONE IS INTERESTED LET ME KNOW ...)
2nd Gen 4Runner Console Lids/Armrest//COMPLETELY intact and VERY good condition; 25$ each(The Brown one IS NOT that Orange, hahaha... Not sure what happened with my Camera... I'll get another pic in the daylight without flash ) (PS> THESE DO NOT FIT 1st Gen 4Runners/2nd Gen Pick Ups)
2nd Gen 4Runner Single Window Switches(from the front passenger and back seats) and 2 Door Lock Single Switches(from the front passenger); $10 Each....... (2 SINGLE WINDOW SWITCHES SOLD/1 SINGLE LOCK SWITCH SOLD)
2nd Gen 4Runner Driver Door Window and Lock Control Panel; 45$
(SOLD... BUT, AGAIN, ASK IF YOU'RE INTERESTED AND I'LL FIND YOU ONE QUICK-LIKE)
2nd Gen 4Runner Green Bulb Courtesy Light; 10$
1st Gen 4Runner/2nd Gen PU Horns; 15$ each(ONE HORN LEFT)
Found another "Japanese Symbol" Toyota Oil Cap.... Still have the "TOYOTA" one as well, below a bit; 15$
1st and 2nd Gen 4Runner/2nd and 3rd Gen PU "TOW HOOK" with keeper and eyelet bracket/Complete; 20$(For adding second Hook as I have in pic below)
My Rig with 2 of them/flipped the eyelet on the driver side....
2nd Gen Tailgate Latch Cables(For 1st Gen 4Runnerites that have the "MY TAILGATE WONT SHUT", this is the cure, 90% of the time. First Gen Cables are rubberized...2nd Gen use a Boot and no Rubberized cables, [which rust from beneath the rubber and then cause the cable to be permanently compromised]These flow VERY smoothly and allow the latch to catch/release/catch again, without trouble. EASY Repair/Mod that WILL USUALLY fix your 'Tailgate is stuck!' syndrome); 25$ for the pair
1st Gen 4Runner Tailgate Latches(You will have to tie your wiring in to the Door Lock Detection wiring/It was compromised at one point before the connector so I snipped it at a few inches before the Latch/NO corrosion and were working perfectly on the Rig they came out of.) ; 25$ for both
Toyota Symbol Center Caps for the Rear wheels[or front wheels with ADD/Non Auto or Manual Locking Hubs]... 3 in Total) ; 12.50$ each/30$ for all 3 (I have 2 as back ups... as I've busted 4 already on my rig/or they flew off after loosing a 'tongue')... I paid 9$ each for them and had to remove the wheels to get them safely....
Full set of 4 2nd Gen 4Runner Cargo Hoops/Tie Down eyelets/with spotless, full set of 8 mounting bolts; 8$ each or 25$ for the set of 4
1st Gen PU Kick Panel Fuse Cover(?) .... In perfect condition; 10$
1st Gen 4Runner Moonroof Main Seal, (SOLD)
Scion tC Front Seats.... 125$//SOLD!
OEM Timing Cover from First Gen 4Runner/22RE, 1987 it came off(Will put up pics asap if needed); 35$/SHIPPED to lower 48
1st Gen 4Runner Back Seat "Pockets" in pretty MINT condition; 50$ for both sides(Will not Separate/ These can be added without TOO much drama... Takes some careful cutting, but it's been done by TERRYS87 AND JASON IN TN ......and a few others as well. They're getting harder to come by. They can be shipped fairly reasonably, they fit inside of each other... I'm guessing 10$ or so.)
Several VSV's; 15$ each(I've wired up 2 of these to my AC VSV and they worked fine. Not positive, but I'd bet they might work for MANY applications where PAIR or other AS VSV's are needed.. I used 2 which were not for AC to work my AC... and 2 which were for AC checked out as well. I can provide a couple Toyota Part #'s, ...but most of it is worn off or only showing part... OR, some of them only show the ND#... NO Toyota # ever was printed on them(Old school AC/VSV like my original// One # is Nippondenso;084600-4180 ... Another is 90910-12073 ..... Another is Nippondenso; 084600-7210 .... Another is ND# _ _ _ _ _ _ - 7420(can't read the first)... Another is Toyota Part #90910-12035 ...... SnobbsDDS has dibs on one if it'll work for his PAIR VSV)
82 Supra Dizzy and Coil Cover/5MGE 15$ for Distributor Cover and 5$ for Coil Cover//SELLING TOGETHER (Distributor Guard Might work with other V6 Dizzy's.... It's got routing cut outs on the sides, etc.... designed for a straight 6.... Coil Guard might work with any OEM Yota Round Coil top... I could try it on mine)......
82(and others) Supra Engine Bay Light/Tested & Working; 25$ (I have NOT wired up the switch... It has to be wired a certain way, I just put 12V to it and even did a video...It works. I'm sure the Depression Button is a ground that's completed when the hood raises. The light DOES come out of that socket and extend to hand on the hood eyelets, etc.... it's on a chord)
1st Gen 4Runner/2nd Gen PU(?) SR5 Map Lights with Mounting Plates, screws and wiring/connectors; 40$ each (as I said, all with the mounting brackets, screws and wiring connector and enough wire.... I HAVE 1 LEFT OF THE DARK GRAY)(1 DARK GRAY SOLD)
2nd Gen PU Rear View Mirror/Dome Light w/out Lens; 10$ each (Bolts right up to 1st Gen 4Runner holes.. Have to run wiring to dome light wiring in A-Pillar(For "DOOR/ON/OFF" capabilities) BUT, ...Lens is ALWAYS damaged at the yards... Well, every one I HAVE seen. They burst into Powder at the lightest touch... Toyota wants 39$ for the lens ... BUT, apparently they're hard for them to find as well... I would sell them for 40$ each with the lens in decent shape.... Just can't find them in tact, sorry )
1st Gen 4Runner/2nd Gen PU Climate Control Face; 25$(SOLD/BUT ASK IF YOU WANT ONE, I'LL FIND ANOTHER ORIGINAL)
2nd Gen 4Runner/3rd Gen PU Climate Control Panel w/Clock; 25$
1st Gen 4Runner/2nd Gen PU EGR Solenoid-Modulators; 15$ each// SOLD! (Both tested fine)
22RE Metal Vacuum Rail; 20$ Rest is sold
[U][I][B]1st Gen 4Runner rear Window Defrost Relay; 5$ w/out Mounting Piece, 10$ with mounting piece /(MANY Available)(IN pic, above, between Window Relays^^^^)
1st Gen 4Runner(and others) 86-87 4Runner ECU's; 100$ Each ( Yep, that's it.... I don't care what others sell them for... They're charging me 70$ for them and I have to drive down and remove them, etc.....Not being sassy, haha.. Just please, don't ask? Thanks )(ONE SOLD/ONE REMAINING)
3VZE Coil/Ignitor Combo, 2 Sets.... Both different part Numbers; 40$ each pair.... (Far as part #'s??? PLEASE don't ask me to look it up? lol...... They both came out of 2nd Gen 4runners... that much I know. Pop the part numbers in and you'll know if they'll work for ya... )
First one;
Second one;
1st Gen 4Runner Door Alarm/Seatbelt Buzzer; 10$
(If you've removed it and can't get your driver door marker light to work nor dome light to work on "DOOR" setting... this is the problem. It has to be installed/But can be modified to be 'silent' or even 'mildly buzzed' if you want, haha)
87 4Runner 22RE(Obviously, haha).... Throttle Body w/Dashpot and working TPS; 125$
(All ready fully cleaned, even tiny ports for EGR)
86-87 AFM(Maybe 85, not sure, part number is there) AFM; 65$
Toyota Vacuum Elbows and Straight Pipes, sold in Pairs, 8$ Pair (Used for Diff Breather Extensions... Run about 10-12$ new, each. Keeping one pair shown, whatever is left).....
1st Gen 4Runner Tailgate Seal in perfect condition; 20$
(SOLD/ BUT AGAIN, I DO SEE THEM WHEN IT'S NOT WRECKED.. SO PLEASE ASK, I MIGHT HAVE MORE SOON)
1st Gen 4Runner "TOYOTA" Grill Emblem; 10$
1st Gen 4Runner Back Seat Ashtray; I have black, brown and gray...5$
1st Gen 4Runner Fusible Link Cover; 10$ (Sticker is still readable but obviously peeling up like they all do haha.)
[U][I][B]
1st Gen 4Runner Switches.... ; 15$ each(Just ask me... I will look at whatever I have in the next few days and let you know if I have them. I have a couple Rear-Defrost Switchs, Rear Window/Lock/Wiper Switches, Deck Lamp Switches.... I will be keeping one Rear Window switch... That's likely it... As I said, ask and I will tell you if I have it/ They are Charging me 10$ each for these and I have to drive there, remove them, etc. ALL of them have the wiring to and behind the Connector, as well)
I have a red and I believe Gray Deck Lamp as well in good cond.; 10$ each(here's the red)...
2nd Gen 4Runner Dome Lamp; 20$ each
(These are what I used for my Front Dome Light Conversion and rear wiper motor ADD-A-LIGHT... in my build thread. They are FAR better quality than the 1st Gen dome light... Take a mild modification of the mounting hole to fit... Bolt holes are the same... I have this Gray one and a Blue one)
2nd Gen 4Runner Dash Lights Dimmers; 10$
1st Gen 4Runner Dash Lights Dimmer(Several); 15$ each
22RE Knock Sensor from First Gen 4Runner w/connector & wire; 20$
1st Gen 4Runner/2nd Gen 4Runner(Believe the same) Rear Seat Pull-Release Pins; 10$ a pair (I have MANY pairs of these..... ask
2nd Gen 4Runner Rear Window Motor; 30$//OIL PRESSURE SENDING UNIT IN SAME PICTURE, OEM, FROM 87 4RUNNER; 15$
(Far as the Window Motor...PRETTY sure the motor is the same... Different Connector.. I'm SURE there's someone who knows, lol)....
2nd Gen 4Runner Rear Wiper Cover Dome Lights(DOOR/OFF/ON)...20$ each/35$ a pair
(Just like I installed in my panels. They hold 37mm festoons and can take up to 6LED Festoons... They are BRIGHT! Three wire, no 'screw' grounding... I added mine to my home made panels and they've come in handy MANY times already....)
Just to give another idea of what I've got as far as those harder to find(at times) smaller parts, VSV's, etc., etc....
I KNOW I have more things that I will be adding to this post as I find them.....
Again, I'm doing this to help my mom... She is already so grateful for all the thoughts and prayers that many of you have offered... She wants to say "THANKS!"... So I am, now, for her.
[/COLOR]
Attached Thumbnails 1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-005-3.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-031.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-029.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-056.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-005.jpg
1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-003-2.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-001.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-059.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-036.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-103.jpg
1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-060.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-049.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-027.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-115.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-061.jpg
1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-114.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-105.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-004.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-006-1.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-111.jpg
1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-108.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-109.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-107.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-072.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-071.jpg
1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-069.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-068.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-066.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-008_zps96f5952f.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-026_zps47d457c2.jpg
1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-113.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-005-3.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-112.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-031.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-029.jpg
1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-056.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-104.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-005.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-003-2.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-095.jpg
1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-001.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-094.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-059.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-055.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-036.jpg
1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-091.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-103.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-087.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-060.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-019.jpg
1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-049.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-079.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-027.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-078.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-115.jpg
1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-061.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-114.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-043.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-105.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-037.jpg
1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-004.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-035.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-006-1.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-022.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-111.jpg
1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-016.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-108.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-020.jpg   1st Gen 4Runner & 2nd Gen PU, etc., Stuff for sale....-109.jpg
Old Dec 19, 2012 | 05:55 AM
92 TOY's Avatar
you have sexy hands.
bump for ya.
Old Dec 19, 2012 | 01:41 PM
Hahahaha... Thanks, Jerry... i think
I just wanna help.... Also have a family grabbing TONS of Non-auto related stuff in a few days... It'll help them out too.. And give me more space in my garage! haha.
Old Dec 19, 2012 | 10:59 PM
Shipping out 15 Items tomorrow... Thanks guys, BIG TIME!
BUMP?
Old Dec 20, 2012 | 03:46 PM
ErikJeanna's Avatar
Sorry to hear about your situation brutha...
Question, I'm dealing with the whole smog thing right now and could use the vacuum rail that you listed for $20. Is that the price shipped or is shipping extra? I.m just up the street from you in Ventura County. I work in Glendale though...
Old Dec 20, 2012 | 06:14 PM
Hey Erik.... Thanks
Yeah, just for the rail... Shipping would likely be around 2-5$... It's a lil long, but not TOO long... and not any odd "L" shape like the L-trim I just shipped today lol.... I'm SURE shipping would be pretty cheap... Cheaper than gas, if you KWIMean? haha.... I'm near Torrance... so if you're going to be down here or something.... lemme know... Otherwise, I could ship it to ya asap, k?
Old Dec 20, 2012 | 07:04 PM
ToyoTech559's Avatar
i just checked. the 1st gen coil is different. i cant use it. thanks tho
i do need a pair in gray if you have
1st Gen 4Runner/2nd Gen 4Runner(Believe the same) Rear Seat Pull-Release Pins; 10$ a pair (I'm PRETTY sure I now have 4 pairs of these..... 2 Gray, 1 Blue, 1 Brown,
Old Dec 20, 2012 | 07:46 PM
snobdds's Avatar
I will take the starter relay. Let me know how you want payment.
Do you have access to any VSV's, the red and blue ones. To be more specific, the red VSV that goes to the PAIR system and the blue VSV that goes to the fuel pressure regulator?
Old Dec 20, 2012 | 08:42 PM
So you want a gray pair of Pull Button Tabs for the Rear Seat Releases, Toyo? Gotcha... Bummer on the Coil/Ignitor... It's odd, ..they're maybe one year apart, but they both have different connectors.. Toyota did that alot. Not sure what the difference is... On one coil, I have the wires... BUT, like with the injectors on 87 and 88 4Runners w/22RE.... TOTALLY different impedance and even connector... DARN THEM! lol. Oh well... if you know anyone that needs a spare, etc.,... let em know. Thanks I'll PM you my paypal if you want. Shipping should be.... OH, A STAMP? lol. Actually, probably a 1-2$ or so, if that's ok? (I'm surprised how many people have told me over the years, "I NEED THOSE PULL TABS!!!!" haha... 2 Pairs sold now... I guess they 'deteriorate' quite easily in bad weather/harsh climate )
Starter Relay plus shipping would be around $18.50 . That work?
I'm not sure I can post my paypal email on here(I need to read that part of the rules, lol.. JUST NO TIME! grrr! haha)... BUT, I'll PM it to ya, k? Sending a check is fine too, if you're rather/or don't have a paypal.(not sure you even need to have a paypal.. .But anyway, I'll pm you all my info).....
Far as the VSV's... I have MANY... but mostly from V6's... I need to get pics, tonight... I'll do that really quick and get them up, ok? See, your 88 has a few things mine doesn't. I don't have a PAIR system on my 87.... And, lots of the connectors are different... So Lemme show ya what I have. I just sold the FPR VSV that I had, today. The one for an 87... But maybe yours is different? I know one thing... I'm using an 86 Celica AC-VSV on my rig(it's in my build)... cuz ours being on our Valve cover?.... not bright IMHO... WAY too hot.. I mounted mine elsewhere, like it is on the celica/tercel... Well, anyway, 3-4 of them WORKED, JUST FINE.. I just had to wire them up different... Then I found one with the same style connector... That's what I am using now. Worked fine all summer. SO, maybe I have one that you could use? Just has to have the right resistance, etc. I can't BELIEVE what they're charging for that crap at Toyota. My buddy got the 3VSV kit for the 3.0, .... 250$! haha.
Lemme look and then I'll post em up for ya, k? (may have grabbed a PAIR one for the hell of it off these couple 88+ 4Runners I snaggled off of, lol)... BBinafew!
Old Dec 21, 2012 | 02:05 PM
coryc85's Avatar
Chef, I'm interested in that fancy map light/mirror combo. Can u estimate shipping to 33076 please.
Sorry about your stepdad.
Old Dec 22, 2012 | 01:03 AM
CORY, SUP? ... Yeah, thanks on the condolences... Sux! ... But, we're all heading there... HOPEFULLY without nearly as much trouble along the way, right? But, still, ... for a diabetic with heart disease and having had cancer, stroke, etc., etc., etc., .......... 85 YEARS? That's pretty amazing!
Sure nuff... I would guess shipping would be around 6$... I COULD remove the mirror and make it more compact... BUT, then you'd have to reassemble with the Jaw-Spring Retaining Cylinder thingymadoers when you get it? lol.. Wouldn't matter much, maybe 1$... But up to you... Lemme know, k?
PM'ing you right now
Old Dec 22, 2012 | 03:04 AM
RAD4Runner's Avatar
Hi Mark,
Pockets and one ECU still available?
See you tomorrow.
-Ray
[B][I][COLOR="SandyBrown"]
Old Dec 22, 2012 | 12:34 PM
See ya when you get here, man... DRIVE SAFE IN THIS NIGHTMARE that is 'L.A. Holiday Roadways Realm' ! hahaha.
Old Dec 22, 2012 | 11:06 PM
Just wanted to say,
THANK YOU, BIG TIME, for all whom have helped, even just offering support or understanding.. It's rough some times for all of us.. I realize that. So just know that I'm VERY Grateful! We'll pay this bill off in a few months....... and it's thanks, in part, to some of you guys/gals! (I realize... sometimes the significant other has to "OK" the purchase, hahaha... TOTALLY get that..... And a lady grabbed something for her hubby, too.. MAN I LOVED seeing that! lol You know who you are, sista! )
*** ALSO;
Wanted to note that I edited my post, regarding 'RAD4runner coming to grab the "1st GEN 4Runner rear seat pockets".... He has modified his rear seat panels to have speakers right where they would go.... So, they just wont work for him. So they're still available, in case anyone is interested but thought they sold. (I've been asked for them before a few times/and grabbed 2 pairs over the last year for a couple people on Yotatech).
Have a VERY Merry Christmas, Happy Holidays in general and an Excellent New Year..... Or in the words of my Stepfather who just passed on, a Hungarian, ....
"Kellemes karácsonyt és boldog új évet"
Old Dec 23, 2012 | 11:14 AM
203Cree's Avatar
First sorry to hear about your family. Tough time of year to go thru something like this. Been there, I know the pain.
Assuming I can talk the wife into it, I'll take a set of rear panels and those B-Pillars off your hands this week. I get paid thursday, so probably by then if you still have them. I need both for my 85.
Old Dec 23, 2012 | 12:25 PM
Sounds good.... Not sure how it will be to ship them, lol... BUT, I'll figure it out, lol... Just need to find a way to ship the panels SAFELY..... Sure, I know the Post Office is UBER Careful and loads, unloads, transports and then over again 2 times with the utmost respect hehehe... but, call me nuts... I just don't trust em! lol. I'm good at packing... but that's a tricky one... Hmmmm... As I said, I'll figure it out... and Have a Merry Christmas and Happy New Year!
Sending a PM, ...text me when you're ready to bite the bullet(when the other half allows it! .... <<<(TOTALLY can relate to that from my past)>>> WHICH, ... I miss, to be honest. BUT, being single has it's good times as well As I remember from the "Hot Girls of Yotatech"... you're pretty blessed in that arena! hahaha.... TTYSoon!
Old Dec 24, 2012 | 12:46 AM
BUMP TTT
Added a couple things... Have a few more coming.... Just haven't had time to post it up just yet. Heck, I can barely keep up with the things people grabbed/sending them out/packing the next, hahaha.... Adding this to a busy life.... well, it makes... a MORE BUSY LIFE? ... Jk, you KWIMean
Old Dec 25, 2012 | 02:18 AM
JohnnyCanuck's Avatar
Sorry for your loss, horrible for grieving families to be thinking of $$ when dealing with a loss.
I will take the bump stops so I can Zuk my truck, let me know total with shipping to my work addy, Chef. 9603 114th Ave. V1J 7C7 Fort St. John B.C. Thanks!
Old Dec 25, 2012 | 11:21 PM
Hey Johnny, .... thanks alot, man
Yeah,.... was a bit trippy not having him around this first Christmas.... not that I'd have heard him during dinner, hahaha... As the Southern Saying goes... "That dog can HUNT!"..... So it goes for Ervin, .... "THAT MAN COULD EAT!"
Hey Johnny, .... I got the Addy, ...but could you shoot me the full name in a PM or Email? I would check with ya first before shipping(But they wont allow me to send it international without a full/true name... I think? haha)...
I got them packed, and it seems to weigh around 2.5 lbs. ..... BUT, it's not asking for dimensions. It just says "Under 24inches Length, etc...." , the "RULES" in other words, but nothing more than that... YET, it's clearly saying 10.85$ USD..........
If I have your full name and 11$ on top of the 30$ USD for the Bump Stops is ok witcha.... Then shoot me a PM as such and I'll shoot it on up to ya in the GWN, tomorrow, ok? If not, no biggie... I'm there often, Parts related or not, haha. (If it's more, which I would be surprised, butcha never know, right? hahaha...Then, well, I'd let you know or just eat it). PM me... I'll send you one right now as well.
Hope you and EVERYONE on Yotatech had a VERY Merry Christmas/Happy Holiday!
Old Dec 26, 2012 | 02:19 AM
My real name IS Johnny Canuck....j\k, pm sent.
