Sponsored by: CARiD
Oil pump removal
Old Nov 10, 2012 | 05:30 PM
nctom's Avatar
Oil pump removal
I'm doing the timing chain on my 22RE this weekend. I have the crank bolt and pulley off. The bolts out on the oil pump.
Do I just pry it off the crank shaft? It is wiggling but not wanting to release. Any advice for me?
Thanks!
Th
Old Nov 10, 2012 | 05:32 PM
rworegon's Avatar
Have you looked in the FSM? Searched other threads?
Old Nov 10, 2012 | 05:44 PM
nctom's Avatar
I have. Everybody that I read just passed over it like it was a no brainer. The FSM doesn't mention it in the section on removing the timing chain. I'm a little stumped.
Old Nov 10, 2012 | 05:51 PM
nctom's Avatar
I just found the section in FSM on lubrication - it talks about an oil pump relief valve plug - maybe that's my problem. I'll take a look at that tomorrow. I seem to remember that part of the pump not having a bolt head - it was just flat.
Old Nov 11, 2012 | 02:02 PM
nctom's Avatar
This is why I posted in the nobie forum: I found another bolt to remove. What do you know, the pump slid right off.
Thanks just the same!
Old Nov 11, 2012 | 02:08 PM
rworegon's Avatar
Hey, glad you found that last bolt. I'm a 5vz-fe 3.4 guy and those 22re's are foreign to me....sorry I was no more help for you.
Old Nov 11, 2012 | 02:32 PM
92 TOY's Avatar
use some cardboard (pizza boxes work very well) and make yourself a template for those bolts. ....especially when doing the timing cover it is imperative you have tose bolts in the right holes because there are a few sizes.
Old Nov 11, 2012 | 02:53 PM
Terrys87's Avatar
I have a cardboard template for all of the components. Water pump,oil pump and timing cover. Lots of different length bolts. Pay attention to torque spec and one will need a little sealant on it when reinstalling everything. Cant recalll right off, but it is mentioned in manuals.
bigjstang
Jun 2, 2025 03:56 PM
smthwsn357
May 1, 2024 07:28 AM
Sep 4, 2015 09:27 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
HRDC0R19
Jul 5, 2015 06:43 PM
