3.0 Vacuum Diagram anybody
I have a 90 3.0 and the throttle body has only three vacuum lines on top and no diaphram at the TPS like the 95 does. The 95 is like new and would like to use it
but can't find a good layout of the vacuum lines for it. It's like three more lines coming out of the new one. I have done a search but no luck.
Thanks
Roger
Thanks
Roger
Could you take a couple of different angle pic's of both TB's side by side?. Something just seems weird. I'm pretty sure that the motor was changed from a 3.0 (3vze) to a 3.4 (5vz-fe) in mid 95.
EDIT: After some thought I'm thinking it's probably different because of manual or automatic transmission and if it has cruise control or not.
I just did the same to my 90 runner since the idle air valve was shot. It will work as long as you hook the right lines up where the old ones hooked up and you may have to plug off an extra port if not already done
montanatruck
Feb 26, 2017 07:07 AM
TokyoD23
Jul 12, 2015 06:01 AM
