After rebuild won't start!!!!!
Hey all. Ok I've got the engine back in, everything hooked up. I had a problem with the alarm so I put batteries in the fob and voila, that's good. I go to start the thing and nothing. I have all dash lights, the fuel pump is running, and I can hear a loud click like the starter solenoid is engaging, but no engine turned over. Any ideas? I have the coil wire to the distributor unhooked so I can get oil pressure, that wouldn't do it. Would it? I have all 4 ground wires hooked up, but I had a head job done with that silvery/gray coating put on it. Would that prevent the grounds from conducting? I put the brand new battery on a charger thinking it's drained and just not enough cranking amps? I had the starter tested at the local autozone and it came back good. But possibly bad? I'm lost any ideas is greatly appreciated. Thanks.
Vargntucson
Jul 4, 2015 12:15 PM
