What happened here?
Old Aug 30, 2012 | 05:51 PM
standarche's Avatar
What happened here?
I took my rear 3rd member out to install my lock right and this is what I find.
Old Aug 30, 2012 | 05:56 PM
MudHippy's Avatar
Pinion chewed on it. When did that happen? Is that what you're asking?
My guess would be before the new gears were installed...
Old Aug 30, 2012 | 06:00 PM
kawasakilewis's Avatar
I'm gonna say soneone set the backlash wrong or your bearings are shot. but I'm no professional
Old Aug 30, 2012 | 06:02 PM
standarche's Avatar
Just wondering what would leave teeth marks there. Couldn't wrap my brain around how the pinion would hit right there
Old Aug 30, 2012 | 06:04 PM
Looks to me like when looking at the picture the botttom of the pinion gears were sweeping into the carrier
Old Aug 30, 2012 | 06:30 PM
waskillywabbit's Avatar
Yep. Pinion was eating on it.
:wabbit2:
Old Aug 30, 2012 | 06:34 PM
standarche's Avatar
I did have a recent problem with the pinion nut not being staked down, took it to pro gear in San Diego and they said it should be good. I'm wheelin on Saturday so hopefully it doesn't grenade on me
Old Aug 30, 2012 | 06:35 PM
standarche's Avatar
Sorry, they restaked it, so hopefully it's good.
Old Aug 31, 2012 | 06:52 AM
MudHippy's Avatar
Well...they might be right. But they did fix it from getting worse atleast. You could replace the carrier fairly easily if you wanted to. They're dime a dozen. Those gears still look just fine to me.
Old Aug 31, 2012 | 07:53 PM
weaselman's Avatar
its the pinion, someone forgot to tighten the nut or it just came loose and was rubbing, it happens. lol
Old Aug 31, 2012 | 08:54 PM
vital22re's Avatar
totally a bro
I'd start saving up. There is a good chance there are micro cracks in the teeth. A few good shock loads and it could go boom. Or it may not. Either way I'd start preping for that.
Old Aug 31, 2012 | 08:56 PM
snowshredder555's Avatar
I've seen this before...
In my first diff rebuild...reused the pinion nut, it came loose about 2 miles from my house, when on the coast side the nut let loose, slamming the pinion gear into the the third case locking the diff completely! Holy dang batman what was that...? One hell of a god awful sound and slam forward and instant stoppage right in the middle of the road...and then the drive shaft came rolling out...I laughed...what else could I do? That's what it takes in my experience to see the case chewed like that.
Old Aug 31, 2012 | 09:28 PM
abecedarian's Avatar
And who knows what that did to the pinion bearings, shaft....
Old Sep 2, 2012 | 02:23 PM
Nick Foster's Avatar
I did the same thing to a toyota sequoia differential. all of the teeth... gone. i decided i would drop it from N to D at 5,000 rpms. for fun.
83yotastockR
11
Nov 10, 2015 06:54 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
creecher10
Sep 30, 2015 03:27 PM
beltcutter
Sep 30, 2015 06:14 AM
mluz013
Sep 29, 2015 05:53 PM
