Sponsored by: CARiD
88 4runner 22r driveshaft compatibility with 86-95?
Old Aug 29, 2012 | 02:33 PM
Manik_markk's Avatar
I'm stuck researching parts to rebuild my recently purchased STOCK 88 4runner EFI shell ( interior, trans, and ecu / harness is intact)
I'm seeing that there are a few different driveshaft and transmission setups on the 22r/22re, and I don't want to run into problems down the road By guessing which driveshaft I should be running.
I've already bought, and will be running a 22r/22re long block (how can I distinguish which is which?)
From the research I've found and understand, 86-95 drivetrains are all quite similar. I'm lost as far as which trans I have, and which driveshaft is needed. If I'm comprehending correctly, the 3vz driveshaft isn't interchangeable with 22r driveshafts / transmissions?
So my question is, which driveshaft(s) are compatible and best to go with on this stock setup?
Sorry for all the NOOB questions. Any help is appreciated!
Old Aug 30, 2012 | 01:48 PM
Bump!
Could use some help !
sandyota
Feb 4, 2021 11:16 AM
icentropy
Sep 16, 2020 02:47 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
87blyota
Jul 10, 2015 04:31 AM
shar
Jul 9, 2015 12:38 PM
