Rear diff/Drive shaft (Pic & Vid)
So I crawled under my truck to grease her up and I found this.
Is there supposed to be this much play?
And I'm assuming a seal has given up...
http://www.youtube.com/watch?v=_FxDO...ature=youtu.be
Well, maybe not all tool boxes, unless you're speaking of the FSM being in the box.
Some of the u-joints are pressed in to the yokes, some are circlip.
The OP's look like the pressed ones. A shop should charge like 15-25 to press them in/out.
As for the fluid leak, the seal is gone. With the worn u-joint, I'd guess the pinion bearings have taken a beating too... though hopefully it's just the preload on the bearings has relaxed a little bit and let the shaft slap the seal into leak mode.
FS[PacNorWest]: Rear chromoly axle shafts
A2theK
Jan 10, 2016 10:18 AM
jerusry
Oct 19, 2015 05:28 PM
Iceman4193
Jul 15, 2015 04:48 PM
toyoda8488
Jul 5, 2015 10:18 PM
