lifted and aligned here are my results
the front checked out fine, but apparently my rear we did the perches a little off. do you think it will be fine?
and before someone asks here is a pic of the truck
I tried to explain once to the front desk clerk when I had my front aligned that I only needed a front end alignment, she didn't believe me and insisted they always do a 4 wheel alignment regardless of vehicle type.
Did you allow the truck to settle out before aligning? I drove mine for a week or so before aligning to let the new springs settle. If not you might want to have it checked again in a month.
The rear alignment is out because the axle isn't parallel to the centerline of the frame. Notice the left wheel is -0.20 and the right is +0.45 degrees: the left is toe'd in, and the right toe'd out. Basically, that means the truck won't track straight- the rear will be kicked slightly to the right so it will have a little dog-tracking going on. Spring sag or even worn bushings could cause that.
perpindicular = rotated 90 degrees
I get what you mean. I said axle parallel to the frame... and should've said the axle perpindicular to the frame.
Thanks for calling me out.
It was a long day and sounded "right" in my head but failed when the fingers translated it to the keyboard.
Flying91
45
Apr 11, 2024 04:39 PM
89fourrunner
Feb 17, 2016 06:52 AM
blinker fluid ,
thats great
