Tacoma transfer case compatibility with other models
Hi guys,
I have a 1996 Tacoma 3.4 v6 with ADD and manual shift stick 4WD select. I'm going to be looking for a used t-case and was wondering which year tacomas would be compatible?
Thanks.
Thanks.
I'm currently in the process of putting a j-shifter from a 95 tacoma into my 01 V6 dbl cab. I ran into a little snag when I went to slide the j-shift t-case into place. There is about 1/4 in gap between the t-case and the tranny, I measured the lengths of the input shafts and the j-shifter is about 1/4 longer (about the gap between t-case/tranny). If the j-shift t-case came off a 4cyl does that make a difference? If so I'm thinking this is the problem I'm having.
yourrealdad
Jul 29, 2015 11:08 AM
crashburnoveride
Jul 10, 2015 06:39 AM
