Gear ratio question
I asked this in another thread but I didn't get an answer...
My truck's stock gear ratio is 3.91
Will I be able to take a 3rd member with an ARB locker geared at 3.93?
I know nothing about the gearing stuff and have no idea if that .02 will make a difference.
Thanks everyone!
Thanks everyone!
According to your sig you're 2wd. Swap it in! The only possible issue would come about with 4wd, but the diffference is small enough that there wouldn't be any anyway.
If you've never set gears, or don't have the tools to do it, have it professionally done. I've done a few ARB's, it isn't really any more difficult than setting the gears themselves, just adds a little more time.
If you are talking about buying a third with the ARB locker already installed, then yes, you can do it yourself. Installing a new third is very easy!
If you are talking about installing the ARB locker into the third member, then have it professionally done.
There's no way a truck came stock with 4.11's in front and 4.90's in the rear. FWIW, that isn't even a 9" gear ratio (4.88 is closest). There are quite a few mismatched stock vehicles. Usually, they are a point or two different with the higher (numerically lower) ratio in front.
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
coffey50
Jul 28, 2015 10:55 AM
