Gear ratio question
Old Jan 28, 2004 | 01:31 AM
Tacoma Dude's Avatar
Question Gear ratio question
I asked this in another thread but I didn't get an answer...
My truck's stock gear ratio is 3.91
Will I be able to take a 3rd member with an ARB locker geared at 3.93?
I know nothing about the gearing stuff and have no idea if that .02 will make a difference.
Thanks everyone!
Old Jan 28, 2004 | 04:50 AM
JD's Avatar
JD
The difference in ratio is insignificant and will not cause a problem.
Old Jan 28, 2004 | 05:23 AM
toy283's Avatar
According to your sig you're 2wd. Swap it in! The only possible issue would come about with 4wd, but the diffference is small enough that there wouldn't be any anyway.
Old Jan 28, 2004 | 05:38 AM
jacksonpt's Avatar
Senior Member
If you're 2wd, the gear ratio doesn't matter - you can swap in a 3rd with whatever gears you want.
Old Jan 28, 2004 | 12:37 PM
Cooooooool!
Old Jan 28, 2004 | 12:38 PM
...another thing, is an ARB air locker installation something I could do? Or is it such a paint that I should get it professionally done?
Thanks!
Old Jan 28, 2004 | 12:47 PM
toy283's Avatar
If you've never set gears, or don't have the tools to do it, have it professionally done. I've done a few ARB's, it isn't really any more difficult than setting the gears themselves, just adds a little more time.
Old Jan 28, 2004 | 12:53 PM
Hmmm... do you know how much I should expect?
... and is $540 still a good deal?
Old Jan 28, 2004 | 12:57 PM
OneTrickToy's Avatar
If you are talking about buying a third with the ARB locker already installed, then yes, you can do it yourself. Installing a new third is very easy!
If you are talking about installing the ARB locker into the third member, then have it professionally done.
Old Jan 28, 2004 | 03:22 PM
toy283's Avatar
There's no way a truck came stock with 4.11's in front and 4.90's in the rear. FWIW, that isn't even a 9" gear ratio (4.88 is closest). There are quite a few mismatched stock vehicles. Usually, they are a point or two different with the higher (numerically lower) ratio in front.
Old Jan 28, 2004 | 04:08 PM
toy283's Avatar
I can see that as a factory mismatch. A little large, but not excessive and certainly feasible.
Old Jan 28, 2004 | 04:10 PM
Flygtenstein's Avatar
Wasn't 4.09 to 4.11 a common Bronco mismatch?
Not to completely hi jack or anything.
Old Jan 28, 2004 | 04:16 PM
zedex's Avatar
My 67 bronco was 4.11 in back, 4.10 up front.
toy283's Avatar
Yup. 4.09 D30/44 and 4.11 9"
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
mskalmus
May 28, 2017 07:51 AM
coffey50
Jul 28, 2015 10:55 AM
smiley52
Jul 11, 2015 05:16 AM
