do i need a body lift for a 2wd 5.3?
im planning on doing a 5.3 swap on my 93 2wd 4runner and was wondering if i need a body lift for clearance. All the threads ive seen say its needed but all of them have also been 4wd. Any help would be great.
Or if you dump the truck intake on the 5.3 and use a LS6 intake, you wont have hood interference problems. (While using the LS6 intake shifts the TQ a little further up the rpm range, it will give you a good bit more hp/tq in the top end - and even with that shift, you will still have over 300ftlbs of tq from 2000 rpm on up. - LSx's are very very torquey and dont run out of breath up top like the old LT1s used to.)
Also look into getting a corvette accessory drive instead of the truck accessory drive - youll save yourself about 2" of wiggle room front to rear.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
Backcountry411
Jul 24, 2015 08:06 AM
