93 toyota t100 starting problems
Working on a 93 toyota t100 with a v6 3.0 liter. It wont spark replaced cap, rotor, plugs, wires, coil, and igniter still wont spark. What do u suggest??
Timing belt slip? Loose ground(s)? Battery charge ok? Circuit Opening Relay (COR) failed? Any work done prior to problem starting?
If you haven't already, take a look at the FSM that most closely matches your rig from the ling in my sig line. The diagnostic section....
Test wiring at the ECM. See page 3 of this pdf:
http://www.ncttora.com/fsm/1990-1995...e/troubles.pdf
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
bigblue82
10
Jul 6, 2015 08:27 AM
