1992 pickup oil pump/front seal leak
I recently replaced the timing chain cover gasket, water pump gasket, oil pump o ring and front seal. Now I have oil coming out of the front seal. I pulled it and replaced it a second time but it still leaks.
Possibly related is the front pulley doesn't seem to be set in far enough and both belts are out of alignment at the pulley. I tried removing the inside gear with no luck.
I had a very bad oil leak which got me started on this project so I'm not sure if I have a bad oil pump.
Any help would be greatly appreciated.
voiddweller
19
May 2, 2016 09:10 PM
