Anybody done a 2WD 3.4 swap?
Old Jun 5, 2012 | 04:40 AM
waskillywabbit's Avatar
Found a primo 95 2WD one owner 4Runner with a bad motor. It's an automatic too. Going to swap a baby Taco 2WD motor and tranny into it. I can't see there being any issues. Thoughts?
:wabbit2:
Old Jun 5, 2012 | 06:27 AM
anthony1's Avatar
I've haven't seen anyone done it.
If you're swapping the trans too then there should not be issues. Maybe the drive shaft need to be shorten or lengthen. I'm not sure if they use the same output yoke or spline.
The shifter might not lined up and maybe some cutting involved.
Those are my guesses as a web wheeler....
Old Jun 5, 2012 | 06:29 AM
James Woods's Avatar
Ive never seen that either, I don't see why it wouldn't work the 2wd 4runner is set up exactly the same as a 4wd pretty much. Are you making a prerunner? That would be cool.
Old Jun 5, 2012 | 06:41 AM
Just making a cheap, nice daily driver for me and pass along to one of my boys in a couple years.
95 4Runner with 164k on it, 2WD, automatic, black with tan interior
One of the nicest I've seen in the south.
I'm picking it up Saturday. I'll post up a build thread as I already got the donor vehicle last week.
:wabbit2:
Old Jun 5, 2012 | 06:57 AM
vasinvictor's Avatar
Sam4Runner put in a a340f 2wd trans and ECU in a 4wd runner. I believe he said he used stock driveshaft and crossmember. Should be cake.
Old Jun 5, 2012 | 07:04 AM
I prefer pie but I'll take cake
:wabbit2:
Old Jun 6, 2012 | 04:10 AM
Trebor's Avatar
Why not just buy a car instead.
Old Jun 6, 2012 | 04:15 AM
Are you a secret J*** lover?
1. It's a Toyota, a nice 4Runner for cheap
2. I can put a motor in it and have an under $2k very reliable 3rd vehicle that even the wife can/will drive.
3. Got two boys driving soon.
4. I already have no less than 5 4WD Toyotas.
5. Repeat
:wabbit2:
Old Jun 6, 2012 | 05:37 AM
Trebor's Avatar
I guess you are right just dont forget to tell the boys where the hubs should be.
Old Jun 6, 2012 | 05:55 AM
He's 10 now but this was a while ago.
Weasel removing dials and faces from hub bodies with the M12 Milwaukee 1/4" cordless impact
Guts separated from dials/faces and into the parts washer
Weasel removing the dial face clip, then the dial face, then the ball, spring and o-ring. He loves this stuff!
:wabbit2:
Old Jun 6, 2012 | 06:04 AM
Cute kid. Our boys would get along famously.
Old Jun 6, 2012 | 05:34 PM
DeathCougar's Avatar
You will have to change oil pans, unless your donor Tacoma is a Pre-runner.
Keep in mind a 2WD 4Runner IS a Prerunner (just 4WD delete) where-as a 2WD Non-Prerunner Tacoma is standard 2WD
Old Jun 6, 2012 | 05:38 PM
It's a "baby" Tacoma, as we call them, not a PreRunner.
Donor is a 97 2WD automatic. Project vehicle is a 2WD 95 4Runner.
:wabbit2:
Old Jun 6, 2012 | 05:42 PM
You'll be swappin pans then. You already have to switch to the T100 dipstick setup anyways, and the 4Runner will have the correct pan, mounts, fan, etc etc.
Old Jun 6, 2012 | 05:43 PM
Yep, the 3.0 pan will work and swap over easily.
:wabbit2:
Old Jun 7, 2012 | 07:57 AM
I don't know how similar it is but my truck started life as a '89 2wd with the 3.0 in it. Manual 5speed.
Swapped in a 3.4L. Had to use the 3.0L oil pan and pickup tube along with the splash shield if memory serves me right. Other then that it was pretty straight forward and similar to every other swap on here.
And yes, I said 2wd... Sorry for all the 4WD lovers! LOL, I've got my jeep for that stuff, personal I think lifted 2WD trucks have a place in life!
Pretty sure my 2WD with a spool will out RTI most other trucks! LOL
If this pertains to you I'm not sure but here's a thread with info on what oil pan combo ended up working on my truck and also an alternator vs. steering box issue I ran into.
https://www.yotatech.com/forums/f160...estion-220709/
Old Jun 7, 2012 | 04:32 PM
slacker's Avatar
I have one in the works as well .. cant offer any advice or info just yet , as i'm just collecting parts ... but it is going into a 91 2WD that were going to use our NEW rear dually fenders on . rear tacoma diamond 8.5 3rd posi , W cromo axles morphed into a dually axle , S/C 5Vzfe , will be the "heavy hauler"
Old Jun 8, 2012 | 06:14 AM
I'm just making a nice grocery getter and 3rd family vehicle so I can look cool crushing the mall.
Picking up a set of 265/65/17 Duelers on 2011 OEM alloys with 1000 miles on them.
$150
What a deal for me!!!
:wabbit2:
Old Jun 19, 2012 | 06:13 AM
Speed sensors. Mine is mechanical. Donor is electronic.
Talked to DC and he said earlier model 2WD Tavoma mechanical speed sensor should/might work.
Anybody confirm this one way or the other?
:wabbit2:
Old Jun 19, 2012 | 08:47 AM
anthony1's Avatar
I got a 5spd with speedometer cable that feeds the instrument cluster. I took the speed signal from the cluster to the ECU and my scanner can read the speed from it.
