Pre 84 Trucks 1st gen pickups
Tranny Grinds when I release the clutch
Old May 7, 2012 | 04:22 PM
Wagonburner's Avatar
I just purchased a 1982 for $300 and I'm new to this so don't beat me up to bad. The problem I'm having is when I push the clutch in and put the truck in 1st gear everything is good until I release the clutch and it grinds and goes no where. Any suggestions? I can take off in 2nd no problem but no first.
1982 Toyota 4x4 4 speed
Old May 14, 2012 | 10:22 AM
DrinkUrJuice's Avatar
It sounds like 1st isn't engaging all the way. What I mean is for some reason when you put it in first the gears are not meshing together completely. Only the tips of the gears are making contact and the grinding noise. I don't know what the fix might be exactly. Shifter linkage could need tightened/adjusted. Worse case scenario is the syncronizing gear is shot in 1st and not allowing it to engage all the way.
Old May 14, 2012 | 12:30 PM
James Woods's Avatar
Could be the shift fork is bad, shifter seat bushing most likely needs replaced anyway, might as well change it and see if there is any improvement, if not the tranny will need to come out and inspected or replaced but for $300 you had to know your hands would be getting dirty.
Old May 14, 2012 | 12:51 PM
Lol,
One could only wish though. Thanks for the info as I will probally just yang it out.
Old May 14, 2012 | 02:48 PM
83's Avatar
83
It is a good idea to always replace the shifter seat bushing before pulling the tranny, just to see if it helps. It's amazing how much that does. It's pretty cheap, and really easy to replace. Might as well try it before pulling the whole thing. Whether you pull it or not, you're going to want to replace that part anyways.
Old May 15, 2012 | 08:52 AM
Will do, No need to make more work for myself if this will fix it.
Thank you
Old Jun 5, 2012 | 02:41 PM
Changed out the shifter seat and a no go. I talked to Marlin and they advised to replace the top plate that holds the shift forks. "damit man".
Dieselmann
Feb 19, 2019 02:57 AM
norcal98
Aug 10, 2015 06:20 AM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
PlayAwhile
Jul 20, 2015 11:36 AM
