1988 Wiring Harness Connector Identification
Old Apr 9, 2012 | 08:01 PM
rrorrer's Avatar
I have two connectors that between swapping engines, I don't know where they go.
It is the blue and black connectors shown on the hopefully attached pic (not my original). Everything else more or less matches, based upon color, but these do not.
Any help would be appreciated.
Attached Thumbnails 1988 Wiring Harness Connector Identification-22re-blue-black-connector.jpg
Old Apr 9, 2012 | 09:09 PM
RAD4Runner's Avatar
It would help if you:
  • Include the components around it so we'll have a point of reference and know where to start looking,
  • YOu also take a picture of what's inside the connector housings; spade terminals? Pin Contacts?
Old Apr 9, 2012 | 11:18 PM
Terrys87's Avatar
I am guessing it is for a 22re. The blue should be your water temp sensor in between #2 and #3 injectors behind the thermostat.
The black one I dont know, mine has never been hooked up. Might be for a automatic tranny or something. You should be fine without it.
Old Apr 10, 2012 | 01:43 AM
rokblok's Avatar
If the blue one is a single wire, flat spade type, I would have to guess some type of sensor. Temp for temperature gauge? oil pressure gauge?
Old Apr 10, 2012 | 07:38 AM
rrorrer's Avatar
It is a 22re (sorry), These are near the back of the engine. As you know the wiring harness routes underneath the intake manifold.
There is a temp sensor nearby not yet hooked up.
I vaguely remember the black one being hooked to something (two connectors, but perpendicular to each other). However, nothing obvious to connect.
Old Apr 10, 2012 | 09:19 AM
Terrys87's Avatar
Here is the blue connector on mine. The black one may go to VSV valve that my truck doesnt have.
Old Apr 10, 2012 | 07:11 PM
Turd Furgeson's Avatar
The black one may have something to do with a/c. My 87 doesn't have a/c and I have the same plug going to nothing. The blue is for temp like every one else is saying.
MO transplant
Apr 23, 2023 11:58 AM
steve miller
Oct 10, 2015 01:40 AM
msane99
Jul 17, 2015 10:13 AM
88yodabasket
Jul 13, 2015 01:32 PM
Johntom240
7
Jul 13, 2015 12:18 AM
