turn signal relay
Alldata shows the same flasher for both 4-way and turn signal, as does the wiring diagram. Why are you pulling it anyway? Turn signals not working? If the 4-ways work but turn still doesn't, then the flasher isn't your problem. Next thing to look at would be the fuse, bulbs, and the switch.
Edit: Just saw your new post. Keep a few extra fuses handy. If it blew a fuse once it is likely to do it again until the cause is found. Glad you got it working and good luck!
Technically, it's part of the integration relay. Which is behind the driver's side kick panel, as shown here...http://personal.utulsa.edu/~nathan-b.../4lighting.pdf
moonpie
Jul 31, 2015 11:58 PM
PopsDad1
Jul 30, 2015 02:21 PM
