Clutch issues, engaging while clutch is depressed.
Old Mar 13, 2012 | 01:13 PM
ravenr106's Avatar
1994 toyota pickup 22re 2wd 5 speed
Been having some problems with my clutch. At first I would have to pump the clutch a few times in order to change gears, then it got to where I couldnt change them at all. So I tried bleeding the system and that helped alittle. Then tried replacing the slave cylinder and that helped alot. But it is still not right. It changes gears better, but while sitting at a stop sign with clutch pressed in, in gear, after a few seconds the clutch starts to engage and I cant hardly get the truck out of gear. Think it needs a clutch master cylinder? Any help would be GREATLY appreciated!
Old Mar 13, 2012 | 01:37 PM
BMcEL's Avatar
Sounds like the master cylinder. Also search clutch bracket fatigue.
Old Mar 15, 2012 | 02:32 PM
ravenr106's Avatar
Ok I replaced both the slave cylinder and clutch master cylinder. It is going into gear easier and not engaging while clutch is depressed but it is still soft. I am going to try driving it some and bleeding the system again. Any other suggestions? Bad clutch?
jasonty
41
Dec 23, 2018 01:00 PM
PlayAwhile
Jul 20, 2015 11:36 AM
1996Taco
Jul 20, 2015 12:02 AM
jgwerth
Jul 16, 2015 03:23 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
