Hard to start after fuel filter change...and worse mpg.....
Old Mar 3, 2012 | 10:47 PM
90_4x4's Avatar
Changed the fuel filter And now it's hard to start after its been sitting longer than 20 minutes. Normally It would crank and fire right up in roughly 1 - 2 seconds now it takes a minimum of 5 solid seconds of cranking .. And now instead of getting 12mpg I'm only getting 8 - 10 mpg!!!!!! Wtf??!?!?!! I'm not leaking any fuel either. Any idea on why this could have happened??? It runs fine once it's started but acts like it looses pressure in the fuel lines... Im going to remove and reinstall in the morning and see if anything changes.
Old Mar 4, 2012 | 12:36 AM
wyoming9's Avatar
Red face
it is possible to have a connection sucking air that does not leak fuel
it does sound like your losing pressure.
Your not leaking any gas at all no gas smell.
which engine are we talking about here??:jessica:
Is this a flared fitting connector or banjo bolts??
Old Mar 4, 2012 | 10:18 AM
90_4x4's Avatar
It's a v6 and it is solid fuel lines with a flare on fuel lines
Old Mar 4, 2012 | 12:32 PM
Mashashin's Avatar
this is just a stupid question here but could it be on backward? or would that even make a difference?
Old Mar 4, 2012 | 02:18 PM
90_4x4's Avatar
No its on correctly I removed and reinstalled today, so hopefully something will change.
Old Nov 2, 2013 | 04:06 PM
Wickline's Avatar
I just changed my fuel filter on 95 4runner 3 liter and am having the same problem. Did you find a solution?
JF9243176
Oct 8, 2017 04:21 AM
bigblue82
10
Jul 6, 2015 08:27 AM
MadMax48
Jul 3, 2015 08:26 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
jmc88runner
Jun 18, 2015 03:39 PM
