81 22R Do I put the head gasket on dry?
I swore I read that 81 22r's had a single row chain and a plastic guide...mine is double and metal. Also, the top of my pistons have a raised rim with a recess in the center, like a pool. Anyone familiar with this setup? Oh, it's a california model, if that makes a difference. I'll post pics as soon as I figure out how. The question now, do I slap the head gasket on dry, or do I put a bead of head gasket sealant around the rim?
Last edited by waskillywabbit; Feb 23, 2012 at 05:28 AM. Reason: Please use relevant titles to what you're asking
81 has a dual row timing chain with metal guides, yes use a small bead of great stuff of orange high temp gasket maker on each side of the gasket, finger tighten the bolts till the gasket maker slightly pushes out the sides them stop and let it sit for an hour or more, them go back and torque the bolts down in a 3 stage crisscross pattern. Hope this helps
This is the correct information...
Please note that Supra head gaskets are known for leaking (the stock ones) and most builders use metal gaskets to replace the stock ones. They all claim the most important factor is preventing future failures is to clean head and block surfaces really well and if possible have the surfaces honed or finished to a particular size grit. I forget the exact # but 30 seems to be the number but this is not 30 grit as in sandpaper but rather a machinist #. I can look this up if anyone wishes, or you can find the info at "supramania". I realize these are different engines, but the same principle should apply. Also, any performance engine should always recieve new head bolts or studs, best IMHO are ARP brand.
