can i make my crossover for my 90 in the 99 frame?
Old Feb 21, 2012 | 08:17 AM
QuickSilver74's Avatar
my 99 parts truck has no body on it so it is very easy to test fit everything on it. i know the steering shaft would be in the way but i dont think the cross over pipe would go that far down. basically what i am asking is if the frame is similar to my 90 as far as the fitment issues go.
if not how did everyone else do their crossover pipes? maybe just with the engine and trans out of the truck?
Old Feb 21, 2012 | 10:40 AM
vasinvictor's Avatar
I don't see any reason you couldn't do it sitting in the frame. Just try it. If it doesn't work, so what- you'll have to pull the motor sometime anyhow.
Old Mar 21, 2012 | 11:22 AM
motocrossaddict223's Avatar
ok not sure if this is the correct place to ask this but if you install headers do you really need the crossover i mean whats it really do? if you run duals all the way down is that a no go? just wondering..dont wanna sound completely stupid.
Old Mar 21, 2012 | 11:52 AM
It's really tight down the passenger side to run any kind of exhaust- like impossibly tight. If you run headers, I believe you still have to "crossover" somewhere toward the bellhousing/transmission to the driver side pipe.
Old Mar 21, 2012 | 03:46 PM
but why is it necessary to run a crossover at all? is it for emissions or to balance out the engine
Old Mar 21, 2012 | 03:53 PM
Lack of room on the pass side to run a pipe
Old Mar 21, 2012 | 03:56 PM
oo ook so its not really necessary..thanks sorry for hijacking your thread there for a little bit
Old Mar 26, 2012 | 11:55 PM
4runrjunkie's Avatar
It also helps to maintain the back pressure needed for these engines. To run a true dual out to the back would be too free flowing and you would lose quite a bit of your low end torque.
but as mentioned, the main reason in this swap is just lack of room on the passenger side.
young buck
18
Aug 27, 2018 02:40 PM
gieselman
Mar 20, 2016 04:34 PM
Sep 4, 2015 09:27 AM
1994toyota
Jul 17, 2015 03:03 AM
Fundy Rider
Jul 16, 2015 01:35 AM
