**sold** 01,Tacoma,Trd,SAS,SUPERCHARGED,5spd 18,000 Seattle Wa
2001 Toyota Tacoma 3.4L V6 4x4 approx 109k miles 5-Speed
Clean and clear Washington title in hand. I have a folder 4 inches thick of papers and receipts
Compression test done in September 200 psi on all 6 cylinders
TRD Supercharger -- this absolutely makes the truck, its very fast and has more than enough power to push the 37in tires. Running 6.5 psi on the stock pulley. And I average 18mpg
Pillar mounted boost and air fuel ratio gauges.
URD USA Fuel Upgrade Kit
D44 Solid Axle Swap
Ballistic Fab D44 1/4" plated steel cover
Front Gear - 5.38 Yukon's
Rear Gear. - 5.29 Yukon's
Trail-Gear leafs
FROR cross member for the T-case
Bilstein 5150 Shocks
Custom shock mounts
Steel braided brake lines
Fenders were professionally cut at Taj Collision in Issaquah
ARB Air Locker in front Comes with air horns
Comes with stock intake manifold and other parts 4 Pro Comp off road lights. 2 driving and 2 fogs.
Timing belt done at 95k
E-Locker in rear
Cloth bucket seats
1.5 inch wheel spacers
Throttle body spacer
Chains
Dash mounted gps
CB
Alpine Deck with amp and 12" Alpine sub
Rockcrawler wheels
Demello rock sliders
Badlands bumper with TI9500 winch +controller
Cooper STT tires 325/80r16 (37x13x16)
Warn Premium Hubs
I used most of these parts from Sky-manufacturing for the conversion.
Also has a Toyota Tundra master cylinder, 4 runner dual brake booster and a Summit Racing proportioning valve.
For the springs I went with trailgear 5"HD springs shackle sprung in the rear using the grease able bolts and the creeper joints: The front axle sits a little bit more forward than stock.
The steering shaft is a custom Borgeson shaft.
Lifted about 9 total inches
The front driveline has a custom long spline made by Bill at Aukeen Drivelines
I know I'm forgetting allot of things, the truck is very clean only 2 dents on the whole truck one is on the drivers side between the bed and the cab, rubbed up against a tree on the first trip out. Its very small and could be fixed with the right tooling. And the second is on the rear bumper about the size of an apple. Backed up into a tree in my driveway. Interior is spotless, could use a new cup holder due to the fact that the rubber has been torn off over time but its pretty simple and has never bothered me. also could use new wheel bearings in the rear axle. they have never been replaced and are beginning to make some noise but it is a pretty cheap and ez fix. The truck has not been used to its full potential has been out wheeling 3 times sense it has been finished. The sas was done just before 100k. Has just under 20k in parts on the truck. All it needs is an alignment and a full tank of gas.
I need to sell it because of the amount of commuting I will be doing with my new job, I hate to sell it but I cant afford to buy a second car for commuting, this is a one of a kind rig there is not many out there that are built as well as this one is.
Cole -- 425 890 7967
Untitled by coleagregg, on Flickr
Cole's Tacoma by theryanmix, on Flickr
D44 Solid Axle Swap
Trail-Gear leafs
Custom shock mounts
E-Locker in rear
Cloth bucket seats
Chains
Dash mounted gps
CB
Rockcrawler wheels
Warn Premium Hubs
Last edited by eastsideyota; Feb 25, 2012 at 06:27 PM. Reason: Added required title prefix
polo451
13
Nov 20, 2016 07:49 PM
