Sick turbo
Sick turbo
Ok so I have an 86 22rte 4x4 truck. I overhauled the engine and sawped out the ct20 for the ct26 but the truck still smokes when it gets warm. The truck is straight piped could that have anything to do with it? The oil supply or return line has a small kink in it but still allows oil to pass through. I am at my wits end with this truck. Any advice as to what it could be?
That or valve cover vent that vents back in right before the turbo. That seems to be common. Mine was sucking the oil out the valve cover,through the turbo,and blowing it into my intake manifold.
I'm goin to put a bunch of pics and video in to one video and then post it to YouTube then y'all can see just how bad it's smokeing and how I have everything ran. I'll add another post with detalls on how to find the video later
Some people plug off the hole where it goes into the intake pluming before the turbo (so you don't have a vacuum leak) and put one of those little "k&n" style breathers on the valve cover part. I built a oil catch can to run between the two and it seemed to work. I also built one for my pcv valve too.
It could still be a bad turbo,these ct 20's are known to be pieces of crap. I did the oil catch can and didn't have oil getting into the turbo anymore but.........I was still getting it oil in the intake manifold,so my turbos done.
) in the bottom of the cans so I can easily drain whatever oil has made it into them.
I know the oil drain on my T3 has to be pointed straight down with absolutely no restriction. I'm running a 1/2" line from the drain straight to the oil pan with no restrictions at all. you could pull the exhaust housing off the turbo and see if the turbine is saturated in oil. If it is and you pull the manifold off the motor and look in at the exhaust ports and they seem to be dry, it's got to be the turbo. Mine uses a little bit of oil and when I pulled the manifold off, the valves had a little wetness on them from valve seals.
