Do you need gasket adhesive under the valve cover grommets?
I took off the valve cover today to take a look at the timing chain guides. I just bought the truck and although I didn't have any indication that anything was wrong, I just wanted to make sure they weren't cracked or broken (the guides looked great!).
I hadn't planned on putting any adhesive on the valve cover grommets when I put them back on, but there was adhesive on the old ones when I took them off.
Do you need a sealant between the grommet and the valve cover before you put the nut back on?
Yeah, I got a new gasket set with new grommets. I'll be installing the gasket in a little bit. I just wasn't sure about whether I needed to seal under the grommets when I put the new ones on. I didn't think that was necessary, but apparently the last guy did because there was black sealant under each grommet when I unscrewed them.
No sealant on the grommets, as said, ......however; DEFINITELY use sealant on the underside of the half moons AND the corners of each half moon(where the valve cover gasket meets the half moon and head....just a TINY bead on all 4 of those corners). Otherwise, the half moons CAN AND LIKELY will leak, sooner than later. This is why it's best to use a new gasket after pulling everything if it's been on there for 100K or more.... Mine, being new, was able to come on and off several times without replacing it.... and as long as I used the RTV on the corners and underside of half moons... NO LEAKS, not a drop, in 5K. But yes, the old gaskets, they get flattened out due to all the heat cycles.
Have fun, man, and welcome to yotatech!
I just did this the other day on a 22RE. The manual doesn't say to use any sealant (although I did put a light coat of fipg since I had it out anyhow for the half moons) and the torque is 52 Inch Pounds.
52 inch pounds is WRONG !!!!!!
If you go to 52 inch pounds your going to hit the rockers off the valve cover.
It was changed via TSB to a lower amount, something like 20 inch pounds or something. But tightening down to just when the grommets squish is about where it should be.
Yeah if I could find the actual TSB to prove it, but most of us who know these engines really well can confirm it. I am 100% positive it is not 52 inch pounds. It's not like you'll break anything, but it will make a little more noise.
I guess I'll just snug it up with a wrench like I was going to in the first place.
See that 'Seal Packing' part number? Not positive, but that's exactly where the sealant goes on the top side(corners) and it's best to always/also use some on the underside of the half moons. (It even shows the guy in the illustration holding/squeezing a tube of goop. lol)>
I, too, do the bolts down to "touch".... I use 2 fingers with a 1/4" drive and 12MM socket. As it BEGINS to compress, that's where one should slow down or stop cranking the grommets down. They expand with heat, and if they're too tight, even if they're not touching the rockers/making noise.... they will dry out and crack much sooner, if torqued down too much.
Hey Mark...yeah it's me, still slowly putting this thing together!
Yeah, I did what you did, I put a good amount of packing on the underside of that half moon plus on top like the manual shows.
GREGO,......................SICKKKKKKKKKKK! LOL..
Nice, man... and yeah, that's what I've read in Haynes, 9#, ...but these things are old and tired/stressed and heat fractures that you can't see, etc., etc., ........so I just trust my hands like a safe cracker! lol.
One more noob question though..
The half moon rubber seals do not seem to push down all the way. They are not flush with the head. I'm assuming once I put down the valve cover and tighten the bolts that all will be well.. but I thought I'd ask since you're all here.
Is it normal that it doesn't seem to sit in the groove all the way?
I wanna know what it is!
