rear diff questions
Old Jan 2, 2012 | 05:50 PM
EFI85's Avatar
rear diff questions
hey guys which third members will work in my stock 854x4 rear axle . I blew the rear end somehow going down the freeway on my way home from tahoe . I wanna get all new 529 gears and lockers but im broke and need to get it up and running for now. Thanks
Old Jan 2, 2012 | 06:19 PM
dropzone's Avatar
Fossilized
any 8" third member(79-95) will fit...V-6 or 4 cylinder..just make sure you get a matching gear ratio or pull your front d/s to avoid any question until you get your 5.29s
Old Jan 2, 2012 | 06:48 PM
bobby_duce's Avatar
what gears you have now? if you have 4.10 you can get a rear third for cheap on craigslist and that will at least get you back on the road.
Old Jan 2, 2012 | 06:53 PM
EFI85's Avatar
I'm pretty sure there 4:10 . I'm going to double check in the morning . Thanks for the heads up . I'll keep looking on CL but as of today in my area there isn't too many for sale . I'll find one soon hopefully .. Thanks
Old Jan 3, 2012 | 04:22 AM
EFI85's Avatar
I found a wrecking yard with a bunch of yotas . If I can use any third from a v6 or a 4cyl as long as its the same gear ratio im assuming the
Axles are all the same spline count but what about the drive shaft flange are they all the same bolt pattern ? Thanks guys!!
Old Jan 3, 2012 | 11:29 AM
4Crawler's Avatar
Likely the same but it may be different, best to measure and see:
- http://www.4crawler.com/4x4/ForSale/...l#Introduction
Not the end of the world to either re-drill the new flange or swap in your old flange or even swap in one of the new triple- or quad-drilled flanges.
Old Jan 3, 2012 | 11:52 AM
dropzone's Avatar
Fossilized
good point on the flange...totally spaced that
I used Roger's Method above when I swapped a rear driveshaft..
just rotate it flange 1/8 of a turn..took me about 10 minutes, just clamped the D/s flange to the differential flange, got me by till i got a new one..
the1998sr5
15
Jul 14, 2020 08:35 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
icentropy
Jul 14, 2015 10:23 AM
87turboPA
Jul 9, 2015 05:58 AM
