Pre 84 Trucks 1st gen pickups
gear ratio on my 82
Old Dec 30, 2011 | 03:46 PM
nwyota82's Avatar
gear ratio on my 82
im thinking of running 4.10's in the rear and 4.11's in the front, but i dont know if that will work or be bad. i tried searching it but couldnt find anything. does anyone think this will work? or should i do 4.11's front and rear? any help appreciated, thank you.
Old Dec 30, 2011 | 04:34 PM
nightstalker's Avatar
match em,
edit: although i wouldnt think it would be a big deal in dirt, but y put undue stress on ur drive train?
Old Jan 1, 2012 | 05:02 PM
Gov't Mule's Avatar
Your '82 should already be set up with 4.10s...pretty sure thats stock.
Old Jan 1, 2012 | 05:37 PM
scuba's Avatar
That's not enough of a difference to hurt anything.
Guys with SAS Tacomas frequently run 5.29's in the rear and 5.38's up front without any ill effects.
Old Jan 1, 2012 | 06:18 PM
BoredOutnJackdUp's Avatar
Exactly what scuba said. Thats too close to even matter. People do it so often and most dont even know it.
Old Jan 2, 2012 | 03:39 PM
igotit's Avatar
a faster turning front would give you tighter turning radius....atleast thats how it works with rc trucks/cars.
Old Jan 2, 2012 | 03:48 PM
dropzone's Avatar
Fossilized
yep should be find...especially since you would only be using 4wd on slick surfaces...
Old Feb 1, 2012 | 05:27 PM
1stnoob's Avatar
I'll be putting 5.29 front/rear locked should help with bigger tires to.
Old Feb 1, 2012 | 06:52 PM
MudHippy's Avatar
Oh...so now it's your thread. And we're supposed to care why exactly? And that's relevant because...?
That was one of the MOST, if not THE MOST, nonsensical newbie first posts I've ever witnessed. Congratulations on that I guess...
Old Feb 1, 2012 | 08:33 PM
Yeah. Seriously.
Go here. They will be much better at assisting you.
http://www.pirate4x4.com/welcome1.php
Old Feb 2, 2012 | 06:42 AM
1stnoob's Avatar
You mad? I take it you installed 4:10 ratio in your's to later find out that's stock?
It's ring/pin 101 when you have a gutless motor (22r) you wanna have a lower gear ratio
(numerically higher number)it will give you more torque/rpm, at the least i would suggest
running something in the high 4 ratio's, but i guess what it comes down to is what you plan on doing with it. Do you plan on putting bigger tires, making it a crawler,wheeler are a commuter rig? Don't listen to me though i don't have 4000 posts.
RatOmeter
Oct 22, 2015 03:17 PM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
