Locked_SR5 22RE to 3.4 Swap
Old Dec 22, 2011 | 07:06 PM
Locked_SR5's Avatar
Hi all,
First post in this section.. I am currently in the process of building my 87 4Runner into a rock crawler (My link to my build is in my signature). I'm always looking for additional input or suggestions on my build
Anyways, to make a long story short, I've been researching and doing a lot of reading for this swap. I currently have all the plugs needed for the swap with the exception of the E5 plug that goes to the 3.4 ECU, and have both the 99 Tacoma and 87 4Runner electrical wiring diagrams. Anyways, can someone from here tell me a good source to buy from and could tell me if this is the correct part # for the E5 plug: 9098-11638
Plug I'm missing
I want to make this
Plugs I have.. From the 22RE: N2 and N3 plugs. From the 3.4: IK2 plug, OBDII plug, and cruise control plug
I have all the plug pin-outs labeled for the swap and have a file on my comp. I plan on doing the swap in August of 2012 (that's when I have to SMOG it again) I want to have a couple of years to troubleshoot before I get it BAR'd to make it completely legal in Cali
3.4 engine harness labeled..
22RE body harness labeled
Additionally, can someone verify the year my engine harness is from. I'm 95 percent sure its from a 99 Tacoma 5-spd 3.4.. Number on the harness is 82121-3D500C61.. I already have the Manual 3.4 ECU, engine, all peripherals from the same vehicle. I just need the E5 plug. If someone has one laying around or is very knowledgeable about the swap at PM me.. I'd like to have them look at my wiring swap schematics to see if I overlooked anything.
Thanks.. I want to make this a 22re to 3.4 swap sticky and will continue to post progress on my build thread..
Old Dec 25, 2011 | 09:08 AM
jasond's Avatar
The 90980-11638 is a 22 pin plug, and doesnt look like any of the plugs on the 99 taco 5vz ecu. The plug that would work for e5 on a 99 taco is a 90980-11218 which is a 28 pin plug and it looks correct according to what I'm looking at. These plugs come empty and you will need to supply the pins to fit in them, you can get those from toyota also - p/n 82998-24020, they come each, so count up how many you will actually need ( I seriously doubt it will be all 28) and then head up to your local dealer.
Old Dec 27, 2011 | 05:02 PM
Locked_SR5's Avatar
Jason,
Thanks for providing me the that very valuable information. Sometimes its hard to get answers here. Really appreciate it. Will be ordering that plug and the associated wires within the week.
Kyle
Old Jan 8, 2012 | 08:17 PM
Locked_SR5's Avatar
Wanted to add some additional info to this thread. Thanks to Jasond, I was able to source the correct plug for my swap, and now I have everything to complete my 3.4 swap adapter harness.
Here is the company info I bought the plug and pins from. They'll have all the other plugs needed for this swap
New United Race tech
www.newunitedracetech.com
Part # 5890 for the 99 E5 Tacoma plug
Part # 5872 for the pins that lock into the plugs (these are the pins for all plugs on the Tacoma ECU)
28 Pin E5 plug
E5 through E8 plugs for 3.4 ECU
Now that I have all the plugs needed for the swap, could someone familiar with 3.4 engines look over the following to see if I identified the wires and pin outs correctly for the IK2 plug (26 pins) and E5 plug (28 pins).
E5 plug and V plug from 87 4runner 22re pin outs
IK2 Plug and N2 and N3 plug from 87 4runner 22re pin outs
Feel free to ask me any questions.
Thanks
Old Jan 8, 2012 | 08:23 PM
Locked_SR5's Avatar
Sorry last pic is just the IK2 pin out for a 1999 Tacoma with the 3.4 and M/T
Here is the pic that was supposed to be in its' place.
Old Jan 17, 2012 | 10:12 PM
Locked_SR5's Avatar
I was able to make my harness for the 3.4 swap.
Here it is.. still need to tie in the ODBII port power supply. They wiring diagram says its supplied from a 7.5 amp fuse. Can i either tie it into the STA line from the IK2 plug, or BATT line or BK line from E5 plug?
I'm also going to have questions regarding the AC system. Can anyone share or show me a couple of good threads regarding AC wiring and the 3.4 swap.
Harness;
Old Jan 18, 2012 | 08:08 PM
dntsdad's Avatar
Just tie it to an IGN source. The w-l wire on the 3.4 stuff should work, or if your are upstream of the harness the its w-r
You surely cannot wire it to the STA wire. that is just an input from the starter letting the ECM know the motor is cranking. The OBD2 would need constant ignition power.
Old Jan 18, 2012 | 08:37 PM
Locked_SR5's Avatar
Thanks Jason. If I remember correctly, I think that may have been the harness to your 3.4 swap when I started this thread. It was a good example of what I wanted to do and I need to give credit where it's due. I know I ordered the RAD triple sticks after seeing them installed in your rig too. I just need to finish fabricating my transfer case parking brake before I can install the duals.
Additionally, where you ever able to get your AC working on your truck? I would like to have the wiring figured out before I do the swap (not too many 22re to 3.4 swaps here and not sure if it's different from the 3.0).
Regards.
Old Jan 19, 2012 | 04:24 PM
dntsdad's Avatar
No Ac still for me. Truck sat a lot of the summer last year but this is going to be on the front burner after I complete the SAS.
I think that Hamish has it nailed, but it doesn't seem like he posts much over here anymore. He send me some info on wiring it in a PM, but I accidently deleted it.
Old Jan 20, 2012 | 10:05 AM
SacRunner's Avatar
It looks like UKrunner got it figured out using the 3.0 AC amp (not sure of differences to 22RE AC amp...if any): https://www.yotatech.com/forums/f160.../#post51497903
In a previous post in the same thread he mentions needing to invert a signal line that controls the idle-up: https://www.yotatech.com/forums/f160.../#post51492778
I plan on using my 3.0L ac amp when I get to that point and trying to follow along with what UKrunner did.
Flying91
45
Apr 11, 2024 04:39 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
deepmarsh
Aug 6, 2015 03:44 AM
94whiterunner
Jul 12, 2015 07:15 PM
