what r some some symptoms of a blown head gasket?
Hello all I'm a newbie at getting under the hood and diagnosing my toyota. I have an 85 pickup re and I don't get any power at full throttle. The truck starts however when I step on the gas there is hardly no acceleration and backfires (sometimes).
Things I've checked: distributer cap and rotor, spark plugs, compression, I've checked the valves spacing and chain to make sure it didn't skip a tooth, timing (also made sure it was at tdc), harmonic balancer (to make sure key way didn't slip).
My question is what are symptoms of a blown head gasket????
Any feed back would be appreciated. Thanks
How would I perform a leakdown test... I did run compression test and the first piston is at 170 2nd thru 4th were at 150ish. I could retest. The engine oil does look chocolatey.
Another factor I noticed was that the exhaust manifold is glowing red...
Milkshake oil is not good. If that is caused by a head gasket then there is water in your oil and you want to get that fixed before your barrings are ruined. I want to hear opinions about the glowing exhaust. Is that caused by the fuel mixture?
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
