Sponsored by: CARiD
what r some some symptoms of a blown head gasket?
Old Dec 15, 2011 | 07:45 PM
sbhern89's Avatar
Hello all I'm a newbie at getting under the hood and diagnosing my toyota. I have an 85 pickup re and I don't get any power at full throttle. The truck starts however when I step on the gas there is hardly no acceleration and backfires (sometimes).
Things I've checked: distributer cap and rotor, spark plugs, compression, I've checked the valves spacing and chain to make sure it didn't skip a tooth, timing (also made sure it was at tdc), harmonic balancer (to make sure key way didn't slip).
My question is what are symptoms of a blown head gasket????
Any feed back would be appreciated. Thanks
Old Dec 15, 2011 | 07:51 PM
SCToy's Avatar
Losing coolant, smoke from exhaust, chocolate milkshake oil, oil in coolant, sweet smelling exhaust.
Old Dec 15, 2011 | 07:52 PM
SCToy's Avatar
compression and leakdown tests can help diagnose too
Old Dec 15, 2011 | 08:24 PM
sbhern89's Avatar
How would I perform a leakdown test... I did run compression test and the first piston is at 170 2nd thru 4th were at 150ish. I could retest. The engine oil does look chocolatey.
Another factor I noticed was that the exhaust manifold is glowing red...
Old Dec 15, 2011 | 10:31 PM
Buck87's Avatar
Milkshake oil is not good. If that is caused by a head gasket then there is water in your oil and you want to get that fixed before your barrings are ruined. I want to hear opinions about the glowing exhaust. Is that caused by the fuel mixture?
Old Dec 16, 2011 | 03:58 AM
rattlewagon's Avatar
Clogged catalytic?
Old Dec 16, 2011 | 06:04 AM
SCToy's Avatar
Yea, gunna have to agree with rattle, clogged cat can cause exhaust not to flow freely and thus the manifold will get very hot, which in turn probably ruined your HG
Old Dec 19, 2011 | 10:23 PM
sbhern89's Avatar
Ok thanks to all for your replies, 2 ppl said the same thing that it could b caused by the clogged catalyic so I will check that out...
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
