Rubbing noise up front when turning cold
Hey all,
First I want to say that I did search for an answer but did not find much in way of an answer. I've got a 93 pickup 4x4. Now that the weather is cold (under 20 degrees) I get a rubbing noise coming from my front suspension (or steering?) when I turn partially - not full lock. The noise actually goes away when I turn to full lock. This only happens until the truck is fully warmed up. The power steering fluid is at a sufficient level and was flushed and replaced a couple months ago. Anyone have any insight?
Thanks
http://youtu.be/w62H0scnEJU
Thanks
So after driving this morning I have diagnosed a bit further. When turning to the right, the rubbing/binding noise comes from the left wheel area. vise versa for turning left. It does not happen in reverse either. Could it be something with the hubs?
Wheel bearings will make a noise somewhat like a grinding noise when turning, but it sounds to me like you have oversized tires rubbing on mudflaps or pinch weld when turning. It may not be evident while parked either.
You're right, tires rubbing wouldn't go away when warm. What size tires do you have, just curious. Could you wheel cylinders be sticking a bit and dragging when cold? That shouldn't only occur when turning however.
Alright, so I got a video of the noise. You'll want to turn your volume up a bit to hear it clearly. This was a left turn, and the noise was coming from the right wheel well area.
Did you check for a cow dying underneath the hood??
Wow that is an ODD noise! If it only happens during turning I would guess the PS pump also. I am, however, no expert on this. Just my $0.02.
Last night I was thinking about it- wondering if it was your power antenna or blower motor? But that's wouldn't explain why it goes away at full lock, etc etc. Still kind of sounds like a tire rubbing on a mudflap or a piece of fender liner. You may have to get somebody to drive, while you hang out of the window/door to try to narrow it down.
