92 toyota pickup won't start when hot
Old Dec 3, 2011 | 08:20 AM
ohale's Avatar
trying to fix a 92 toyota pickup. when you drive it and it gets warm it will not start. after i sits for abour 45 minutes it will crank up. the motor turns over very well. if you use starting fluid it will fire up after a couple of trys. i know it must be a fuel issue, i've replaced the core relay and fuel filter. any suggestions? any help appreciated.
Old Dec 3, 2011 | 09:12 AM
sharpy46's Avatar
pretty common issue that i, myself have gone thru. check the cold start inj time switch....and the cold start injector. also follow the fuel pump test procedure outlined here....just do a lil searching.
Old Dec 3, 2011 | 09:22 AM
sharpy46's Avatar
check this out
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
6th Gear
19
Dec 10, 2019 07:31 AM
Crazychris1871
Jun 27, 2016 10:38 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
newzingo
Jun 24, 2015 01:50 PM
94hiluxZE
Jun 22, 2015 10:42 AM
