Low Dollar 4x4 Project!
My plans are to continue fixing the 100 little things that are wrong with it (as inexpensivly as possible) It needs alot of love. I've already put a starter on it and exhaust flange gaskets/nuts/lockwashers. I also fixed the pass. side door. (it wouldnt open from the outside) Fixed the antenna, cleaned the interior, changed fluids, etc. Have to replace the tail lenses, the passenger side mirror, and the meter hood on the dash. Also need the driver's side turn signal lens.
The thing stinks really bad, but the CAT was removed, and the tail pipe is nonexistant. I need a new muffler system but dont want to spend a whole lot.
pipe is cheap like 20 for a lot of it and a flowmaster is like 60 or 70 you can get a cheap aftermarket muff for like 40 im doing mine this only take ya a hour if that id stay away from glass packs on it unless u want to have it sound like a rice burner
Good luck with getting it all fixed up. There's tons of good information and helpful people here on yotatech to help you out. For replacement parts check out:
http://www.partsgeek.com/ymm/1993/toyota/pickup.html
http://www.car-part.com/
jasonty
41
Dec 23, 2018 01:00 PM
crashburnoveride
Jul 10, 2015 06:39 AM
