trd passenger drop headers on 3.4 in 90 p/u
Old Nov 16, 2011 | 08:32 PM
toyotanick's Avatar
this is probably not the best place to ask this question but would anyone happen to know if the ted headers for the 3.4 will fit in my truck. i know i had to do a driver drop with the manifolds to avoid something, not sure what. and i was wondering if the headers would fit my truck because of this obstacle?
Old Nov 17, 2011 | 04:08 PM
4x4runr's Avatar
Im about to drop this in my swap:
http://www.bjsoffroad.com/CartGenie/prod-970.htm
I'll let you know what I run in to. Probably just the fuel line, brake line and clutch lines.... But I can move those around. So we'll see.
Old Nov 17, 2011 | 05:43 PM
toyotanick's Avatar
awesome! which headers put out better numbers? TRD or doug thorny etc? i know the trd's are expensive!!! but doesn't always mean they are the best.
Old Nov 17, 2011 | 06:53 PM
vital22re's Avatar
totally a bro
the clutch slave cylinder is in the way
Old Nov 22, 2011 | 07:01 PM
toyotanick's Avatar
do headers make a huge difference when supercharging? and does anyone make a header that will fit. i have a 3inch body lift, would this help the scenario anyhow?
Old Nov 22, 2011 | 09:35 PM
4x4runr's Avatar
Is that for his application or mine? Or both of us??
Old Nov 23, 2011 | 08:49 AM
Greg_Canada's Avatar
Look for some downey or NWOR headers, make a custom y-pipe. Doubt the TRD's / thorleys will fit...
Old Nov 23, 2011 | 11:19 AM
I "believe" mine are the downey headers and they're close on the clutch slave! Close enough that I wrapped them as best I could with header wrap to try and keep the rubber boot and slave alive in general. I have a 3" body lift and my bigger issue actually was on the driver side where the steering shaft wanted to go right thru the headers. A torch and a hammer fixed that though! LOL
Really bad picture, it's all I have...
Here's my header clearance on the shaft though... I'm on solid motor mounts so I don't have to worry about it moving at least.
Old Nov 23, 2011 | 03:06 PM
deyzin's Avatar
This is what I did for slave clearance, it worked for stock exhaust clearance.
Its a pull slave cylinder for transaxle buggies.
Old Nov 23, 2011 | 04:41 PM
4x4runr's Avatar
That is a great idea! Thanks! I'll look into that
Can you take a pic of the bracket that's holding it in place pls.
Old Nov 23, 2011 | 10:38 PM
dntsdad's Avatar
Interested in this as well. Can you post up more info/pictures? maybe a link to what this is and where you would get it.
Old Nov 24, 2011 | 08:16 AM
deyzin's Avatar
CNC is the brand. http://www.mooreparts.com/store/product/2249/CNC300B/
I welded a tab on the back side of the release fork and made a bracket that bolts up to the transmission.
This is the only other picture I have right now.
This worked but with 4x4, space was razor thin, Ive since swapped the exhuast to the driver side.
Old Nov 24, 2011 | 05:01 PM
toyotanick's Avatar
ok so basically, would any of you recommend doing headers? it looks like a lot of work, and a big maybe. besides, finding downey headers are difficult.
Old Nov 24, 2011 | 06:36 PM
4x4runr's Avatar
I put the headers on yesterday(thorely) and things will have to be modified.
-Header is 1/4" from starter
-Flange will have to be remounted to face away from chasis
-collector looks like it might be hitting the chasis.
-slave cylinder and fork is hitting the collector
I'm going to try and make it work but if Trail gear comes out with a header soon that is similar to Downey's then I will probably get that one.....
Old Nov 27, 2011 | 09:50 AM
toyotanick's Avatar
why would you get trail gears? are they suppose to be building them for the swap? or because they will be cheaper?
Old Nov 27, 2011 | 06:06 PM
4x4runr's Avatar
They are currently working on a header system for the 3.4 should and be out in about 30-90 days. They didn't give any specific type of design but kinda hinted it would be long tubes similar to Downeys
Old Nov 27, 2011 | 10:09 PM
toyotanick's Avatar
badass. long tubes do not use a crossover pipe over the transmission correct? and which is better for bottom end? or does it not really matter with a s/c?
Old Nov 28, 2011 | 06:20 PM
4x4runr's Avatar
Bottom end i believe and no crossover above but below the trans if you kept it as a single exhaust. I can't comment on the s/c since I haven't really done any research on one other that how much they cost haha
Old Nov 29, 2011 | 05:22 PM
toyotanick's Avatar
lol. ok cool, bottom end is what i want. it looks like i will be waiting for trail-gear!
Old Nov 30, 2011 | 06:43 AM
Long tube's will give you power throughout the range.
