trd passenger drop headers on 3.4 in 90 p/u
this is probably not the best place to ask this question but would anyone happen to know if the ted headers for the 3.4 will fit in my truck. i know i had to do a driver drop with the manifolds to avoid something, not sure what. and i was wondering if the headers would fit my truck because of this obstacle?
Im about to drop this in my swap:
http://www.bjsoffroad.com/CartGenie/prod-970.htm
I'll let you know what I run in to. Probably just the fuel line, brake line and clutch lines.... But I can move those around. So we'll see.
I "believe" mine are the downey headers and they're close on the clutch slave! Close enough that I wrapped them as best I could with header wrap to try and keep the rubber boot and slave alive in general. I have a 3" body lift and my bigger issue actually was on the driver side where the steering shaft wanted to go right thru the headers. A torch and a hammer fixed that though! LOL
Really bad picture, it's all I have...
Here's my header clearance on the shaft though... I'm on solid motor mounts so I don't have to worry about it moving at least.
Can you take a pic of the bracket that's holding it in place pls.
CNC is the brand. http://www.mooreparts.com/store/product/2249/CNC300B/
I welded a tab on the back side of the release fork and made a bracket that bolts up to the transmission.
This is the only other picture I have right now.
This worked but with 4x4, space was razor thin, Ive since swapped the exhuast to the driver side.
-Header is 1/4" from starter
-Flange will have to be remounted to face away from chasis
-collector looks like it might be hitting the chasis.
-slave cylinder and fork is hitting the collector
I'm going to try and make it work but if Trail gear comes out with a header soon that is similar to Downey's then I will probably get that one.....
Bottom end i believe and no crossover above but below the trans if you kept it as a single exhaust. I can't comment on the s/c since I haven't really done any research on one other that how much they cost haha
